DIY 3.6 Pentastar Oil Change
Discussion in 'General Jeep Discussion' started by chris4x4, Aug 5, 2017.
  1. Aug 5, 2017 at 4:04 PM
    chris4x4 [OP] With sufficient thrust, pigs fly just fine Moderator
    Changing your oil is basic maintenance, and on the 3.6, its super easy. First, make sure you have some things on hand.
    *Rags
    *Oil Drain Pan
    *6 quarts of your favorite Motor oil
    *Oil Filter
    *13mm Socket
    *24mm Socket
    *Ratchet Wrench
    *Small Extension
    *Gloves
    Its recommended to change the oil on a warm engine. Some trains of thought are a cold engine has all the crap in the oil at the bottom, so it all comes out. Others say the warm engine has all the crap suspended in the oil, and allows it to all comes out, rather than sit on the bottom of the pan. I change the oil on a warmed up engine. After getting it up to operating temp, I let it sit for 5-10 minutes.
    Take your engine cover off and set it aside where you wont trip over it:
    My fluid of choice is Pennzoil Ultra Platinum, and an OEM Filter.
    PLEASE NOTE:
    The filters for a 2012 - 2013 are different than for a 2014 and up 3.6. The 2012-2013 use MOPAR Part Number MO-744:
    The 2014 and up use MOPAR Part Number MO-349:
    MAKE SURE YOU ARE USING THE CORRECT FILTER.
    Loosen the Oil Filer Cap, and using the 13mm socket and ratchet, remove the Oil Drain Plug:
    While its draining, Lets change the Filter. Find the Filter Canister. I place a rag around it to prevent oil from getting on the engine if I spill.
    Using the 24mm socket and ratchet, loosen and remove the Filter Canister Cap. The Filter will be attached to it, and come out when you pull the cap off.
    Remove the old filter and remove the Gasket on the cap, and replace with the new one that comes with the new filter. Be sure to rub some oil on it before installing it on the cap.
    Install the new filter. It will make a "Click" when its seated properly.
    Install the new filter and cap back on the Jeep. Torque the cap to 18 Ft./Lbs. Don't over tighten, as it can crack the housing and leak.
    Re install the Drain plug on the oil pan, and torque to 20 Ft./Lbs. Don't over tighten, as you can strip the threads.
    I keep a couple empty bottles from each oil change for using the residual oil in them to lube the gasket on the filter canister, and then cut the bottom for a nice, tight fitting funnel! :)
    Add 6 Quarts of your favorite oil, and tighten the filler cap.
    Bonus Tip: With the additives in most oils, shake the bottles really good before dumping them into the engine. This ensures the additives are mixed into the oil, and not stuck to the sides....bottom, whatever.
    Fire the engine up for a few minutes, and check for leaks. After you shut it off, check the level.
    Make sure you put the engine cover back on!! (Ive driven off without it on a few occasions )
    Take your used oil to a local Oil Recycling drop off.
    NOW.....You need to reset your Oil Change Indicator.
    To do this:
    Turn the ignition switch to the on/run position but do not start the engine.
    Fully depress the accelerator pedal slowly 3 times within 10 seconds.
    Turn the ignition switch back to the off/lock position
    And youre done! :)
    Doing this yourself is easy, fast, and gives you the opportunity to examine the underside components of your Jeep. Check Drive Shafts, leaks, and for anything that looks out of place.
    Happy Jeeping!
    tomrr, Anderson, chriswcalif and 7 others like this.
  2. Aug 5, 2017 at 4:40 PM
    Great DIY that anyone can follow.
  3. Aug 5, 2017 at 6:13 PM
    dougbbbb
    dougbbbb Well-Known Member
    Great post. Anyone use synthetic oil in their Jeep.
    Doug
    Billy1234 and JKBob 25 like this.
  4. Aug 5, 2017 at 6:20 PM
    Run full synthetic in all my vehicles. Starts easier, smoother during winter seasons and revs much nicer with the MT. Bumps the OCI a bit and go to Walmart for the best everyday price.
  5. Aug 5, 2017 at 7:08 PM
    Great DIY Chris4x4. After owning my XJ for 14 years. Of coarse numerous oil changes on my back. Was cool to find out filter was up top in my JK.. Pain in the ass lining up drain pan and filter on the Cherokee. Love this JK oil change now. Lol.Just one so far. But man.....what a difference. No more screw on filters for me. :)
    Also, I've been using full synthetic oils since Mobil 1 came out with theirs. Used it first in my Yamaha Virago. Noticed the difference after 2 oil changes. Stuck with full syn's since. And you can say what you want about Walmart. Yes, there are some.....umm....different customers in their stores. But have to agree with aggrex. Their prices are fantastic. Ex: just picked up a name brand air filter for 10 bucks less than my local auto parts place.
    Again. AWESOME DIY Chris 4x4. And just a side not. I happen to notice you hide your face where ever possible. Are there a few Wanted Posters out there for you? Or just camera shy. :cool:
  6. Aug 5, 2017 at 7:39 PM
    I was having my wife focus on getting the details of the oil change. Here is a "selfie" I took at work.....
    14232654_10209544074111244_2372203301611_75f6c371395ec4f5bc5c56f3e68c6bddf41d0ce2.jpg
    JKBob 25[QUOTED] likes this.
  7. Aug 5, 2017 at 7:45 PM
    Mind........I didn't spend much time on my hair in that picture......
  8. Aug 5, 2017 at 7:51 PM
    Yeah.....i saw that pic. You posted it NUMEROUS posts ago. Time to move on. And yes....i also saw your rock you put eyes on. I'm on to you dude. ;)
    chris4x4[QUOTED][OP] likes this.
  9. Aug 5, 2017 at 7:52 PM
    Oh by the way. You were having a good hair day if you saw my hair line. Lol:annoyed:
    Moo Moo. I like Bovines.
    chris4x4[OP] likes this.
  10. Aug 5, 2017 at 7:58 PM
    More recent. Came home from work, and decided to work on some bolts for some reason....
    10407349_10209117467123659_4794831486491_832ba1204a93753ed5a189e425dbe3077feb8d6a.jpg
  11. Aug 5, 2017 at 8:02 PM
    Work on some bolts. Or just throw some testosterone a around. Either way....it works. I see Dancing with the Stars calling soon. Remember the little people when you make it big. Jeeps.net. ;)
  12. Aug 5, 2017 at 8:03 PM
    LOL!!! I was cutting some bolts to the correct size I needed for a project.
  13. Aug 5, 2017 at 8:07 PM
    Cool. ...ok.... Another DYI. Or a..Umm I just need to spray some sparks around with cool glasses on. The wife loves this. I'll leave it at that.....Sorry for the edit
    Some thing tells me. If we lived closer together. You and I would knock back a few. I set myself up at times. And you see the opening...and take it. It's a all good.lol. And I'm sorry to say. You set yourself up for me. Gotta love it. It's all about having fun. And I look forward to your next post bustin me. Cause I'm going to have a come back. Keep'em Chris4x4. I love it. :argue:
  14. Aug 5, 2017 at 8:34 PM
    Ok....back to Chris4x4 post. And it is an awesome post. The time he put into this post. Takes us less time to do the actual work. And I applaud his effort. This is an awesome forum. And I hope we can keep it going good.
    On that thought. I would just like to add my 2 cents.
    Chris4x4 mentioned several times using your favorite oil. My favorite these days. The cheapest full synthetic at my favorite Walmart. And not a no name brand. Quaker State, Penzoil, etc. I always pick up a name brand.
    Back to my point. Back in the 60s and 70s we use to push a heavier weight oils thru older motors that may have lost compression. And in some cases, it did work. But with today's motors. You will only hurt your motor. If your jeep requires 5 w 20. Then use that oil. Be it full syn. Or regular oil. One of the worse things you can do to your motor. Is ask it to push thru a heavy weight oil thru the small and very tight clearances with various engine components. An oil that the manufacture doesn't recommend. Stick to what the manufacturer reccomends. Don't mean to repeat myself. But I will. Use what the Manufacturer suggests. Be it full sync. Or regular oil. Don't use a heavier weight oil.
    Keep on Jeepin
  15. Aug 5, 2017 at 8:53 PM
    Again, Chris great write-up! Your JK is older than mine and my OCD kicked in when I saw that rusty oil pan. Perhaps a quick rattlecan shot of flat black?
  16. Aug 5, 2017 at 8:56 PM
    That's actually dirt from up north out here. Red rocks = red dirt :)
    Anderson and JKBob 25 like this.
  17. Aug 5, 2017 at 8:57 PM
    Cant tell much, but after the change, you can see the glossy black from where I cleaned off the pan:
  18. Aug 5, 2017 at 8:59 PM
    Thanks, OCD is decompressing now...LoL
    chris4x4[OP] and JKBob 25 like this.
  19. Aug 5, 2017 at 9:02 PM
    :rofl::rofl:. LMAO. Peace out. Bed time.....:rofl:
  20. Aug 24, 2018 at 5:10 AM
    Jeep4Life
    Jeep4Life Well-Known Member
    2012 Jeep Wrangler Unlimited
    I’m a rookie in this department. Think I’ll try my first oil change myself next time I need one thanks to this step by step tutorial. Oil filter needs to be changed every time correct? And Castrol ok for name brand? How much on average can I save doing my own oil changes?
