YJ newbie
Discussion in 'New Member Introductions' started by CJ400455, Nov 13, 2019.
  1. Nov 13, 2019 at 6:53 PM
    CJ400455
    CJ400455 [OP] New Member
    Cam
    1994 Black Wrangler
    350 LT1, Turbo 350, 4" lift, 33-12.5/15
    Thanks for a great site! I just got a 94 YJ project. The previous owner did a lot of good things, but there's a lot left to do/fix. The good: 350 LT-1, Turbo 350, 208 T-case, 4" Rancho lift, 33" tires, heavy duty steering linkage, aluminum radiator with electric fan, t case and fuel tank skid plates, Adams driveshafts, new soft top.
    The bad: cracked engine block, trans shifter cable is seized, front axle engagement is now cable operated (need to try to locate a place to put the cable), and other things I'm sure I'll find as I go along
    I'm anxious to get this on the road
    Any and all help and advice will be welcomed!
    Thanks!
    Cam
  2. Nov 13, 2019 at 8:08 PM
    Welcome @CJ400455 ...nice YJ project that has the engine upgrade some jeepers aspire to have. That choice of V8 power should be ez to source, modify and build. Post some pics
  3. Nov 14, 2019 at 7:50 AM
    CJ400455
    Cam
    1994 Black Wrangler
    Thanks aggrex! I'll try to get some pics put up this weekend
  4. Nov 14, 2019 at 4:26 PM
    Welcome to the site!
  5. Nov 15, 2019 at 5:44 AM
    CJ400455
    Cam
    1994 Black Wrangler
    Thank you!
