Which Track Bar
Discussion in 'Wrangler TJ (1996-2006)' started by GunnytheJeep, Apr 9, 2019.
  1. Apr 11, 2019 at 11:49 AM
    #21
    Harleymick
    Harleymick Well-Known Member
    Mick
    1999 Jeep Wrangler Sahara
    Don't we all have the best Jeep ever built overall including our own modifications? Whether it's the engine, drive train, suspension, lights, functionality or looks if you aren't upgrading or tweaking guys and ladies on here are passing you. A jeep is kind of like a house and yard, it's never finished.
    A word of advice at least for TJ owners. Find the two low points on your frame and drill a half inch diameter hole up through the bottom of the frame. There are plenty of slots and openings in the sides to let water, mud and salt in but no way for it to get out. Your thoughts?
  2. Apr 11, 2019 at 11:55 AM
    #22
    Sounds like solid advise and yes we all drive the best version of our own Jeep's i just think the original rubi's we're the best production Jeep's ever
  3. Apr 11, 2019 at 12:25 PM
    #23
    Harleymick
    Mick
    Definitely an awesome jeep straight off the sales lot.
    TJ_abuser likes this.
  4. Apr 14, 2019 at 11:58 PM
    #24
    Harleymick
    Mick
    About that track bar......Learned this one the hard way as I do most everything. Since you have a lift it is an adjustable track bar, right? Since you have changed it I want you to measure the distance from the frame to the outside tread on both rear tires. They may or may not be the same anymore, after I changed the track bar Ronda's weren't. The right wheel stuck out about 3/4" further than the left. (Ronda is my TJ) I unhooked the track bar on the lower end which has the adjustment with the full weight of the Jeep on the ground. I gave the left side of the back bumper a little rocking push and they were within 1/4" of being the same. I bumped it again with my bum and it was dead on. I then adjusted the track bar to match the bracket so the bolt would easily slide in and out and torqued it down.
    If you already knew all of this....Never mind!
  5. Apr 15, 2019 at 6:23 AM
    #25
    GunnytheJeep
    GunnytheJeep [OP] Member
    Adelina
    2006 Wrangler Unlimited Rubicon
    3.5” Rubicon Express lift with Fox shocks
    I will do that when I get home tonight!! Thank you so so much
    Harleymick and TJ_abuser like this.
  6. Apr 18, 2019 at 11:39 AM
    #26
    Rc Jeep
    Rc Jeep Well-Known Member
    Ryan
    '16 Rubicon
    May be late to the party but, huge fan of Currie for steering components.
  7. Apr 18, 2019 at 5:05 PM
    #27
    GunnytheJeep
    Adelina
    Thank you!!
  8. Apr 18, 2019 at 7:29 PM
    #28
    Hard to go wrong with Currie Jonny joints . Just out of my budget for a couple years
    GunnytheJeep[OP] likes this.
  9. Apr 22, 2019 at 6:29 PM
    #29
    I do have Currie Correctlynk tie rod and drag link. But I run Teraflexes front and rear Monster HD track bars. Very competitive with Curries. Noticeable difference over stock bar.
