What have you done to your JK today?
Discussion in 'Wrangler JK (2007-2017)' started by Bob, Jul 24, 2016.
  1. Feb 4, 2019 at 9:21 PM
    #641
    Rubicon Express. They're lil beefier than others on the market. I like the poly pivot greaseable ends. I also applied a dab of grease on the mounting pins. Easier to slid off. Never know when ya might need to disconnect to navigate and crawl a speed bump at the mall. :eek:. Well....in my case anyway. :p
    Broke 2 sway links on my XJ just messin around. Thought these were a good upgrade for the JK.
    TJ_abuser likes this.
  2. Feb 10, 2019 at 6:49 PM
    #642
    Bilstein 5100 shocks and steering stabilizer.
    Much better ride and less bump steer over old Skyjacker system I was running. Also Synergy relocation bracket and tie rod clamp.
  3. Feb 11, 2019 at 4:48 AM
    #643
    boondoc89 Well-Known Member
    It's hard to beat a bilstein shock. I got them for my dual steering stabilizer set up. Had the 5100's on my tacoma also and they worked great
    TJ_abuser and JKBob 25[QUOTED] like this.
  4. Feb 11, 2019 at 11:10 AM
    #644
    Great shocks Bob. There is no right or wrong, but I don't install the boots on my jeeps. Here in the south we have lots of Gulf moisture and the boots cause rust on the shock and shock shaft. I have to say that the JK is pretty difficult to change the shocks as far as shocks go . . . good job. I was cussing mine after the last rear upper shock mount bolt snapped off. Dang rust.
    TJ_abuser and JKBob 25 like this.
  5. Feb 11, 2019 at 7:52 PM
    #645
    I wasn't going to install the boots. But it hit me I might damage the shafts and cause them to leak. But I noticed they have small holes on them, thinking they are drainage holes for rain and moisture. But the more I think bout it. I may cut boots off. I see your point @OFFGRID . And I do agree. Rust can be an issue. And what these cost. Wanna keep'em shiney and new.
    As far as install. Old Skyjackers came out with out an issue. Bilsteins went in..not so much. These things are so gas pressurized. It's a work out gettin them to collapse into mounts.But after my first test ride. Well worth the effort. Greatly improved ride. And thanks Peter. I am seriously considering cutting off boots. Great point.
    Steering stablizer....also a significant improvement. Kinda slightly pullin to the left. But that's apparently an issue with it. But I had an issue before this install. Gotta swap tires side to side and see if that helps. But overall...Greatly improved my ride.
  6. Feb 11, 2019 at 8:05 PM
    #646
    What duel kit are you using? I'm running a Currie tie rod. Was wondering if I could run a duel set up With this tie rod.
  7. Feb 11, 2019 at 9:45 PM
    #647
    You have salt up there. The boot might actually help . . . I don't know. You are right about the gas charged shocks. Not fun to try and compress while installing.
  8. Feb 12, 2019 at 12:16 PM
    #648
    It's a kit that I found on ebay. Its direct from bilstein. I'll see if I can find it later after work and I'll post it here for ya. As best I can remember it never mentioned anything about fitment around beefier aftermarket tie rods.
  9. Feb 12, 2019 at 4:27 PM
    #649
  10. Feb 12, 2019 at 4:34 PM
    #650
  11. Feb 13, 2019 at 11:13 AM
    #651
    Ok boys and girls... I got a question. As of lately I'm only getting heat coming out of a few of my vents. It's good hot heat. But the driver side vents aren't blowing hot air. Could the duct work have come off inside the dash?? Is my heater core taking a shit?? Anybody have some advice on what's causing this??
  12. Feb 14, 2019 at 2:08 PM
    #652
    TJ_abuser and boondoc89 like this.
  13. Feb 14, 2019 at 2:33 PM
    #653
    Check the blend box door actuator. If lucky cleaning up the gears might work otherwise replace. Next inspect for broken blend doors which can be PIA.
  14. Feb 14, 2019 at 5:54 PM
    #654
    Thanks fellas!! I'm gonna look into this weekend. I'm hoping this is all it is. I'll post back up and see if I get her fixed up
  15. Feb 18, 2019 at 9:37 AM
    #655
    monkeygrip
    monkeygrip Active Member
    Sid
    2015 Wrangler Sport
    I put wheel locks on today. I’ve always worried about the spare on the back getting stolen.
  16. Feb 18, 2019 at 11:12 AM
    #656
    Good move for deterring an ez opportunity! Doesn't take much to lose a $300+ spare tire in less than 60 seconds. Just keep the KEY secured in the Jeep each+every time after usage.
  17. Feb 27, 2019 at 6:55 PM
    #657
    Rubicon Express duel stabilizer kit, Synergy tie rod clamps, and Bilstein stabilizers. Much improved over a single. Steering is abit tighter. But feels really nice. Thanks to @boondoc89 for helping spend my money, and suggestion.
    TJ_abuser, Bob[OP], OFFGRID and 2 others like this.
  18. Feb 28, 2019 at 2:35 AM
    #658
    Old River Bill
    Old River Bill Well-Known Member
    SE TEXAS
    2018 JKU Sport
    Did this a couple weeks ago. Added the Rigid Spots to my A-pillars. So far so good! Still need to fine-tune the beams. A good graveyard project.
    BETWEEN RAIN STORMS!!
    ORB
    TJ_abuser, Jeep4Life, OFFGRID and 2 others like this.
  19. Feb 28, 2019 at 7:19 AM
    #659
    Man that looks beefy!! :benchpress:
  20. Feb 28, 2019 at 4:05 PM
    #660
    Running Currie tie rod and drag link. With "pothole season" in full swing here in the Northeast. :annoyed:.Need all the protection I can get.
