What have you done to your JK today?
Discussion in 'Wrangler JK (2007-2017)' started by Bob, Jul 24, 2016.
  1. Jan 18, 2019 at 12:33 PM
    #621
    Neither have I but new rust-free ones come pre-coated. Could be a recommendation from the past when rotors were turned instead of tossed.
  2. Jan 18, 2019 at 3:10 PM
    #622
    Rotors for my LJ are 40 bucks they charge 20 each at oriellys to turn them that's an easy choice
  3. Jan 18, 2019 at 5:39 PM
    #623
    boondoc89 Well-Known Member
    Ah ok!! Now I know what you mean. It's a type of treatment that prevents corrosion during times of idle correct??
  4. Jan 18, 2019 at 9:03 PM
    #624
    Excuse the confusion as I was typing on the phone. New caliper mounting bolts come pre-coated with threadlocker(TL). Some references recommend using TL on the caliper mounting bolts and using new bolts. Like you I have not used TL on these caliper mounting bolts but TL could ensure these bolts don't come loose.
    JKBob 25, Jeep4Life and boondoc89 like this.
  5. Jan 19, 2019 at 1:52 PM
    #625
    Jeep4Life
    Jeep4Life Well-Known Member
    2012 Jeep Wrangler Unlimited
    So I should add TL to the bolts if I'm not gonna add new bolts then is what I'm getting?
    Also, adding TL will the bolts still be easily removed without a pressure tool?
  6. Jan 19, 2019 at 2:03 PM
    #626
    I have reused the caliper mounting bolts (bracket) without TL with no issues on several vehicles. Discussion for TL on caliper mounting bolts completes the installation guide.
    Jeep4Life and JKBob 25 like this.
  7. Jan 19, 2019 at 7:45 PM
    #627
    I don't mean to hijack the current conversation. Just what I did to my JK today. 20190119_142526.jpgNew snow shoes. Mickey Ts Baja mptz'3s and Rubicon Express quick release sway links. 20190119_122605.jpg
  8. Jan 19, 2019 at 8:31 PM
    #628
    Looking good! Being disconnected never felt so good....just do it
  9. Jan 19, 2019 at 8:38 PM
    #629
    First time I was disconnected. Felt so good. Every one should try it. Very liberating. :cool: :bananadance:
    chris4x4, Jeep4Life and aggrex like this.
  10. Jan 20, 2019 at 4:56 AM
    #630
    I remember my first time driving disconnected... thought I was gonna roll my rig goin around a roundabout intersection at 10 miles an hour. It was exhilarating lmao
    Jeep4Life, JKBob 25 and aggrex like this.
  11. Jan 22, 2019 at 5:52 PM
    #631
    Old River Bill
    Old River Bill Well-Known Member
    SE TEXAS
    2018 JKU Sport
    Actually it was Monday afternoon I did this. I started out just wanting to clean and treat the fender flares. Then cleaned tires and wheels. And then, went ahead and washed it. Looking good!
    Par for the course.....it’s now RAINING AGAIN! Of course, this doesn’t work in June, July, and August. Go figure!!
    ORB
    Jeep4Life likes this.
  12. Jan 30, 2019 at 5:17 AM
    #632
    Jeep4Life
    So, went to change out my front brakes and when I removed them they aren’t worn at all. Put the same ones back in. Seems like the squealing is less now when I brake then before. I did spray some brake cleaner before putting everything back on.
    Could something else be causing the squealing besides the pads when I brake? Thought I’d ask you guys before I remove and check the rear brakes.
  13. Jan 30, 2019 at 11:09 AM
    #633
    Put a little anti squeak between the pad and piston, and make sure everything is clean. That should help.
    JKBob 25 and Jeep4Life like this.
  14. Jan 31, 2019 at 8:34 AM
    #634
    What brand are this kit?
  15. Jan 31, 2019 at 3:16 PM
    #635
    Jeep4Life
    Really small fix today. Changed out my side marker light on my fender that burned out. Took about 30sec.
  16. Jan 31, 2019 at 6:08 PM
    #636
    That qualified as an up grade. :benchpress:.
    Jeep4Life[QUOTED] and TJ_abuser like this.
  17. Jan 31, 2019 at 6:14 PM
    #637
    It's Frankensteined. Alil this....alil that. :cool:
    Not sure what your askin bout Peter @OFFGRID .
  18. Feb 2, 2019 at 12:05 PM
    #638
    Automan21
    Automan21 Well-Known Member
    Just put these on
  19. Feb 3, 2019 at 12:19 PM
    #639
    I mean what brand are the Quick release swaybar links. They look easier to disconnect than most styles like these.
    JKBob 25[QUOTED] likes this.
  20. Feb 3, 2019 at 12:51 PM
    #640
    Automan21
    Also did this the other day.
    Got the fender liners with a SS plate but decided to cut some plexi and put the led marker light behind it after swapping out my fenders for some flat steel ones.
    OFFGRID, boondoc89, JKBob 25 and 3 others like this.
