What have you done to your JK today?
Discussion in 'Wrangler JK (2007-2017)' started by Bob, Jul 24, 2016.
  1. Sep 17, 2018 at 1:08 PM
    #541
    Billy1234
    Billy1234 Well-Known Member
    William
    1997 XJ 2 door
    None yet
    Very nice!
    SJfamilyjeep, TJ_abuser and JKBob 25 like this.
  2. Sep 17, 2018 at 1:49 PM
    #542
    Which ones did you get?
  3. Sep 18, 2018 at 10:27 PM
    #543
  4. Oct 4, 2018 at 5:19 AM
    #544
    Jeep4Life
    Jeep4Life Well-Known Member
    2012 Jeep Wrangler Unlimited
    Not sure where to put this so I put it here.
    So pissed right now.
    Construction truck flipped a rock onto my windshield as I was passing him this morning and gave me a 1” crack! It's a 1" hairline crack, would they be able to repair or do I need to replace it? And if I need to replace would they have the jeep graphics that go all the way around the windshield or do I need to purchase that myself and would they install the graphic if I purchase before service?
    So guess I’ll be scheduling for Safelite to come out! Ugh!!!!!
  5. Oct 4, 2018 at 7:27 AM
    #545
    Rc Jeep
    Rc Jeep Well-Known Member
    Ryan
    '16 Rubicon
    Safelife sells oem replacement glass, they will give you the option for either their glass or for about $20-$30 more the oem glass that has the Jeep graphics on it.
    Check with your insurance. Some states such as Arizona give 2 glass replacements per year with no deductible
  6. Oct 4, 2018 at 7:55 AM
    #546
    Too bad about the windshield but its truly a Jeep thing with the flat glass on the roads. Similar Jeep graphic decals can be applied to graphic-less windshields
    JKBob 25 and Jeep4Life like this.
  7. Oct 4, 2018 at 9:41 AM
    #547
    Jeep4Life
    Just got off the phone with my insurance company and Safelite. They are replacing it. No deductible in Florida, Yay!
    So I'm getting a new windshield(graphics included) on Monday.
  8. Oct 4, 2018 at 12:32 PM
    #548
    aggrex i just flip my hood back on my windshield have never used the prop rod lol
    chris4x4 and Jeep4Life like this.
  9. Oct 4, 2018 at 1:02 PM
    #549
    Yup that is a unique jeep feature for ez access to areas under the hood.
  10. Oct 8, 2018 at 12:50 PM
    #550
    Jeep4Life
    All done installing new windshield. Looks like it just stepped off the factory line(and came with all those little upgrades I've done of course).
  11. Oct 10, 2018 at 7:32 AM
    #551
    Blue Baby Sound
    Jeff
    Build threads in sig
    ARB twin was installed, air lockers plumbed and stainless brake lines done. Oh, and she finally got her windows tinted :)
  12. Oct 10, 2018 at 10:34 AM
    #552
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Why is there not a shop like this near me in Syracuse ny. Dam it.
  13. Oct 10, 2018 at 10:47 AM
    #553
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Since I've been seeing all this locker stuff anyone ever use or heard of a lunch box locker?? What's the advantage to ot and the disadvantage to having one?
  14. Oct 11, 2018 at 12:18 AM
    #554
    Advantage is cheap easy install. Disadvantage is they don't hold up as well as a detroit locker. I can install one in about 3hours, no regearing and they cost around $250. It is something I would do to get me by while saving for my 1tons.
  15. Oct 11, 2018 at 2:18 PM
    #555
    OFFGRID how are truetracs to install, I believe that is the torsen locker. I have factory limited slip in rear
  16. Nov 25, 2018 at 6:47 PM
    #556
    Olympic 4x4 Products rear bumper. Also 3" LED pod reverse lights. Quadratec makes a plug and play wire harness for them.
    DustStorm4x4, chris4x4 and aggrex like this.
  17. Nov 27, 2018 at 9:12 AM
    #557
    Truetracs install like installing any new differential be it locker, open diff or limited slip. You have to re-shim the carrier as if you were regearing. You're looking at the minimum 5 hours and could be as much as 12 depending on how patient and anal your are at getting your gear pattern when setting up the new shims.
    Next Truetracs are not lockers. They are a form of limited slip differential (LSD). The difference is that LSD have clutch packs giving resistance to the differential causing both wheels to spin under slippage, but the wheel with the least resistance (the one in the air) gets the most power. The Truetrac does this with helical cut gears in place of the spider gears instead of using clutch packs which wear out after 30k miles or so. Truetrac's advantage is that they will likely last the life of your vehicle's axle where you have to rebuild LSD clutch packs every 30k miles
  18. Nov 27, 2018 at 10:10 AM
    #558
    Jeep4Life
    Gave it a good wash yesterday!
    Ended up pulling the trigger on the KC lights during the Black Friday weekend sale. Will be my Christmas gift to myself so will sit under the tree for a month before I install it.
  19. Nov 27, 2018 at 10:13 AM
    #559
    You can aways pickup the jeep a different xmas gift or wrap the empty box under the tree LOL
  20. Nov 27, 2018 at 10:49 AM
    #560
    Jeep4Life
    Lol, yeah but the problem with that is the wife would then know I bought these already.
    She won’t find out until Christmas this way.....
