What have you done to your Cherokee today?
Discussion in 'Cherokee' started by Bob, Jul 24, 2016.
  1. Jul 22, 2018 at 4:32 AM
    #141
    acerwin
    acerwin Well-Known Member
    Andrew
    Laurens, SC
    2001 jeep Cherokee xj
    Custom
    Ordered some coilovers for it.
  2. Jul 26, 2018 at 12:21 PM
    #142
    Southeast Overland
    Seneca, South Carolina
    Went wheeling. Broke some stuff and rearranged some stuff. No need for to worry about the guy standing below the Jeep, it was anchored and very stable on its side.
    ~Jeff
    Rey88, aggrex, JKBob 25 and 2 others like this.
  3. Jul 26, 2018 at 2:51 PM
    #143
    acerwin
    Andrew
    Laurens, SC
    Custom
    Looks like a fun time
  4. Jul 26, 2018 at 7:49 PM
    #144
    Stable in its side?? You weren't tryin to do that....we're ya....Lolll.
  5. Jul 27, 2018 at 7:22 AM
    #145
    Southeast Overland
    Nope, lol Luckily everyone was all good. Should have seen me running away running away from that Jeep while it was rolling. I felt like Indiana Jones running away from the big rolling rock. :rofl:
    It was a rough weekend for us, literally everyone in the group was on their side at least once, for no other reason besides it was just wet. You would slide into a big rut and then you are done, it was like Jeeps on ice.
    ~Jeff
    JKBob 25[QUOTED] likes this.
  6. Jul 27, 2018 at 8:12 AM
    #146
    Rey88
    Rey88 Well-Known Member
    Temecula California
    93 XJ 4 door
    Just did a water pump and thermostat, yesterday I took it to get front drive shaft u-joints replaced/ have rear shaft balanced.
    And then after that continue on my list of parts that need updating. Lol
    Prerunner1982 likes this.
  7. Jul 27, 2018 at 8:15 AM
    #147
    Looks like a waterpump and thermostat for my '00 are in the near future.
    It doesn't overheat but it runs warmer than it should even when the temps are in the mid 90°s it runs 210° or just a little above.
    Radiator, e-fan, and fan clutch are all new.
    Easy job, just not what I want to be spending money on.
  8. Jul 27, 2018 at 8:19 AM
    #148
    Rey88
    Temecula California
    93 XJ 4 door
    Yeah I hear ya brotha, I thought that replacing both would fix my overheating issue, it helped a lot. But looks like replacing the radiator might be needed. Fan clutch is okay. But as far as not wanting spend money on stuff like that I'm right there with you, I bought this about a month ago and have been replacing parts due to the lack of maintenance from previous owner(s)
    Prerunner1982[QUOTED] likes this.
  9. Jul 30, 2018 at 11:44 AM
    #149
    The old 2 door moved under it's own power yesterday. First time in 3 years it's moved.
    Has a clattering sound that I believe it detonation due to the 3yr old gas.
    Going to drain as much as I can and add some new to see if that clears it up.
    No check engine light, temp just below 210°, 13.9 volts, good oil pressure.
  10. Jul 30, 2018 at 1:44 PM
    #150
    On a positive note at least you can cross those items off the to-do-list and know it was done and done right.
    Southeast Overland and JKBob 25 like this.
  11. Jul 31, 2018 at 12:06 AM
    #151
    acerwin
    Andrew
    Laurens, SC
    Custom
    I’m pretty sure I’m going to have to replace my radiator sooner or later. I like the one Jeff from @Southeast Overland did on his.
    Southeast Overland likes this.
  12. Jul 31, 2018 at 7:30 AM
    #152
    Southeast Overland
    I went with the Mishimoto Aluminum Rad, Flow cooler water pump, all new hoses, new 190 thermostat, ZJ Fan and a completely stand alone transmission cooler setup. It will idle all day with the AC on in 100 degree temps and never go above 200. Probably did not need to do it, but man I hate vehicles that overheat and the constant worry that comes with it. '
    ~Jeff
  13. Aug 4, 2018 at 9:15 PM
    #153
    Rey88
    Temecula California
    93 XJ 4 door
    Radiator and fan clutch today.
    JKBob 25 and Southeast Overland like this.
  14. Aug 6, 2018 at 5:48 AM
    #154
    3yr old gas out, mid grade 100% gas no ethanol in. Runs much better.
    Added a little more caster angle, no more wandering.
    It's getting there.
    Rey88 and JKBob 25 like this.
  15. Aug 13, 2018 at 11:59 AM
    #155
    93 2 door:
    Drained the trans and filled it with Redline MT-90.
    Topped off the tcase.
    Took it for a drive to the gas station and had a front passenger caliper lock up on me on the way home. :annoyed:
    Took this pic this morning on the way to work in the DD XJ.
  16. Aug 15, 2018 at 11:25 AM
    #156
    Rey88
    Temecula California
    93 XJ 4 door
    So my journey of replacing all old Parts that the previous owner(s) did not/ fluid exchanges continues......here it goes.
    This is not in order
    93 xj 4 door
    Shocks
    Oil preassure sending unit
    Water pump
    Thermostat
    Fan clutch
    Radiator
    Coolant system flush
    Oil change
    Steering damper
    Front and rear shaft u-joints
    Rear Shaft balanced
    New cat/ o2 sensor
    Front breaks and rotors
    Stopped power steering leak (loose hose)
    Updates to follow
  17. Aug 15, 2018 at 11:32 AM
    #157
    Impressive! Just imagine for a second if you owned one of those transverse mounted engine vehicles and try the same parts replacements :annoyed:
  18. Aug 15, 2018 at 11:34 AM
    #158
    Rey88
    Temecula California
    93 XJ 4 door
    Oh man, I couldn't even imagine how much more expensive it would be smh
  19. Aug 27, 2018 at 5:38 AM
    #159
    Yesterday I changed the water pump and tensioner pulley on the 93. Need to do calipers too, I swapped a caliper from my 97 to replace the one that locked up last weekend. I have the calipers just ran out of time to do them yesterday. Carrying them with me just in case another one locks up as they are easy to replace with the intent on swapping them this coming weekend.
    Drove the 93 to work today... handed off the keys for the 00 to my 17 yr old daughter. :goingcrazy::help:
  20. Aug 27, 2018 at 9:53 AM
    #160
    Not sure what's the main culprit for locked up calipers : age, rust, old fluid, crappy rebuilt parts, sitting too long or just all the above.
