What have you done to your Cherokee today?
Discussion in 'Cherokee' started by Bob, Jul 24, 2016.
  1. Mar 4, 2018 at 7:43 PM
    #101
    @acerwin What kit are you using on the front axle?
  2. Mar 4, 2018 at 8:35 PM
    #102
    acerwin
    acerwin Well-Known Member
    Andrew
    Laurens, SC
    2001 jeep Cherokee xj
    Custom
    Artec’s ram guard for full hydro.
  3. Mar 5, 2018 at 9:21 AM
    #103
    OOOOOhhhh! I did not know they had one. I need more money!
    Rc Jeep likes this.
  4. Mar 5, 2018 at 4:08 PM
    #104
    acerwin
    Andrew
    Laurens, SC
    Custom
    Yeah it’s a little expensive but well worth it.
  5. Mar 16, 2018 at 11:56 AM
    #105
    Nothing real constructive lately... :bored:
    Got tired of the crap stock halogens and got some LED headlights. Man what a difference and so far no RFI.
    However, if the key is on the lights will glow even with the light switch off as there is 7.72 volts going to the lights and that is enough to make the LEDs glow dimly. If the lights contained a resistor like the CANBUS lights do this wouldn't be an issue, also a common upgrade is to install a headlight harness that includes relays and pulls power directly from the battery rather than through the switch as it currently does....this upgrade would also fix the glowing. As it is the glowing isn't hurting anything and I won't get pulled over for not having my headlights on. I do plan on upgrading the harness as well but even without these lights are great. Will definitely be putting some on my project XJ as well.
    Offroad798, chris4x4 and aggrex like this.
  6. Mar 24, 2018 at 1:54 PM
    #106
    Southeast Overland
    Seneca, South Carolina
    Had some fun parking at the shop this morning.
    ~Jeff
  7. Mar 25, 2018 at 5:06 PM
    #107
    Did a little flexing today...
    Would be a 951 ramp travel index if it was on a 20° ramp. 1000 on the ramp is perfect, back tire touching the front of the ramp. IMG_20180325_124441.jpg IMG_20180325_124550.jpg
  8. Mar 25, 2018 at 6:19 PM
    #108
    Hey Hey Hey. Get off her. She looks like a minor. :cool:.
  9. Mar 30, 2018 at 3:34 PM
    #109
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    flush system,backflush heater 16 times, new rad is in,,,all is well.
    heat went from 110 to over 150!! engine temp same.
    tyanny tomorrow,oil next...runnin great
  10. Apr 1, 2018 at 3:35 PM
    #110
    2oldjeeps
    did tranny and oil/filter. need to do o rings on filter adapter but couldnt loosen torx bolt. maybe next time. also need to do lube again.
    havin fun keepin it runnin great...
  11. Apr 9, 2018 at 7:36 AM
    #111
    "Installed" a Ram Mount phone holder in the daily XJ... I know, big mod.... but hey I had to break out the drill. :D I do like it though.
    I also installed an Ironman4x4fab steering box brace.
    Apparently there is a rare steering box casting that causes a clearance issue with one of the clamp tabs.
    Andy said he has only seen this one other time. Nothing a little grinding won't take care of since I already had the grinder out as I had to clearance the front lip of the brace to clear the front receiver hitch that uses two of the same bolts per side.
    Even though the front cross member is slightly bent by a previous owner the brace still installed without much fuss.
    Can't wait to get this XJ back on the road.....getting closer.
    Also have to give kudos to Andy who responded to my FB Messenger inquiry regarding the steering box clearance issue on a Sunday. I sent the message not expecting a response until Monday, but within minutes he got back to me.
  12. Apr 12, 2018 at 9:04 AM
    #112
    Southeast Overland
    Installed a new to me ARB bumper and winch on my Jeep last night.
    ~Jeff
    OFFGRID, acerwin, JKBob 25 and 4 others like this.
  13. Apr 13, 2018 at 8:55 AM
    #113
    If I could only like more than once. Very nice XJ.
  14. Apr 17, 2018 at 2:57 PM
    #114
    Southeast Overland
    Thank you sir, not bad for a 1987 if I do say so myself. My very first AMC titled Jeep!
    ~Jeff
  15. May 3, 2018 at 5:15 AM
    #115
    Loading it up to go camping with some friends of mine. No cool trails or anything, just some camping, setting up portable ham radio stations, fishing, etc.
  16. May 7, 2018 at 9:32 AM
    #116
    Southeast Overland
    My Xj got some cooling system love the other day, Mishimoto rad, Flowcooler water pump and all new Continental hoses.
    ~Jeff
    acerwin, JKBob 25, chris4x4 and 2 others like this.
  17. May 7, 2018 at 7:57 PM
    #117
    In Have no idea what you just said there. But it looks good. Me likey. :thumbsup:.
    Southeast Overland likes this.
  18. May 8, 2018 at 6:34 AM
    #118
    Southeast Overland
    The skinny of it is, I spent more money on the cooling system then I did the Jeep :bananadead: hahaha
    ~Jeff
    JKBob 25[QUOTED] and chris4x4 like this.
  19. May 14, 2018 at 10:31 AM
    #119
    Southeast Overland
    I broke mine. Yay.
    ~Jeff
  20. May 14, 2018 at 5:11 PM
    #120
    Back story?
    Rc Jeep likes this.
