What have you done to your Cherokee today?
Discussion in 'Cherokee' started by Bob, Jul 24, 2016.
  1. Dec 9, 2019 at 9:52 AM
    #241
    Blower motor speeds quit working, ended up being part of the mode control switch. Doesn't appear to be available except as used so I bypassed it and used a switch and relay to send power to the speed switch and blower motor resistor.
    Also found out I had some water intermix in the front differential due to a gash in the vent hose so ran new vent hoses for the front axle and tcase, cleaned the diff, and filled her back up.
    "If woman don't find you handsome they should at least find you handy."
    JKBob 25, aggrex and Billy1234 like this.
  2. Dec 9, 2019 at 2:01 PM
    #242
    Think it would help to use some 1/2" wire protective wire wrap on those hoses to prevent scrapes?
  3. Dec 9, 2019 at 2:07 PM
    #243
    No, with the extra suspension travel I have now the front pinion (driveshaft not currently installed) grabbed the breather hose and pulled it down and proceeded to chew on it. I saw it hanging (a while back) and secured it back up but apparently I didn't see where the pinion had chewed on it.
    Using "reinforced" fuel line now.. but I have it zip tied up and over to the control arm and then up the firewall.
  4. Dec 9, 2019 at 2:19 PM
    #244
    Billy1234
    Billy1234 Well-Known Member
    William
    1997 XJ 2 door
    None yet
    image000000(1).jpg blurry but its fixed!
    JKBob 25, Prerunner1982 and aggrex like this.
  5. Dec 13, 2019 at 9:42 AM
    #245
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Started the jeep for the first time since the swap. Runs amazing found a bunch of sh#$ wrong with the other motor when I took it out. Took awhile but shes alive and healthy no leaks no issues what so ever! Excited to get back in it.
    BigNuge, JKBob 25 and aggrex like this.
  6. Jan 1, 2020 at 7:33 PM
    #246
    cpttuna
    cpttuna Well-Known Member
    earl
    XJ-98-00-01-and 01
    ss exhaust-viper coil
    Installed an extended idle on the silver 2000 XJ. This is similar to the extended idle found on XJ's with the police package. All you have to do is pry off #1 plastic cover on the ECM(driver side near air cleaner box) there are 3 plastic covers. The one closest to the headlight is the correct one. Towards the front of the vehicle, the first wire in row #2(solid gray wire) is the wire you want to splice into. Run a wire from it through the firewall and I mounted a toggle switch on the plastic housing that is about a foot from the gas pedal. On the other side of the toggle switch, run a wire to a good ground. You now have an extended idle if you need it. It will take the idle to about 100RPM should the need arise. Here's a pic of my jeeps.
  7. Jan 1, 2020 at 8:30 PM
    #247
    :thumbsup:
    Sweet dude. Good to hear.
  8. Jan 6, 2020 at 1:38 PM
    #248
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Replaced power steering pump amd lines going to it.. it kinda went bye bye 5 miles from home. Getting good at working on this thing haha
  9. Feb 23, 2020 at 5:51 AM
    #249
    Jasons4.6
    Jasons4.6 Active Member
    Jason
    Black 97 cherokee sport
    4.6 stroker, m90 supercharger, true dual exhaust with sidepipes, old school 6 pack mopar hood scoop, and 3.55 gears front and rear
    Put headlight covers on the Cherokee
  10. Mar 27, 2020 at 2:04 PM
    #250
    Jasons4.6
    Jason
    Rebuilt and repainted my m90 supercharger today
    Prerunner1982 likes this.
  11. Mar 29, 2020 at 7:22 PM
    #251
    New steering box, pump, and hoses.
  12. Mar 30, 2020 at 7:19 PM
    #252
    cpttuna
    earl
    XJ-98-00-01-and 01
    Picked up 24 NAPA gold 1515 oversized oil filters for my XJ'S
  13. Apr 21, 2020 at 5:16 AM
    #253
    Jasons4.6
    Jason
    Replaced the rear upper control arm in the wifes liberty yesterday. Then the rf cv shaft,axle seal and bushing, rf hub bearing, front calipers, rotors and pads. Ugh.. not pleased on how much work is involved just to replace the cv shaft
  14. May 27, 2020 at 2:52 PM
    #254
    Recently added some more comms. :D Not many people I can't talk to now.
    Jasons4.6 and aggrex like this.
  15. May 29, 2020 at 5:12 AM
    #255
    Jasons4.6
    Jason
    Installed 7th injector onto side of intake for better atomization yesterday
    chris4x4 and Prerunner1982 like this.
  16. Jan 9, 2021 at 3:22 PM
    #256
    dillard99
    dillard99 New Member
    I changed all fluids for my 2019 Cherokee 3.2L on this page:
    https://www.searchforparts.com/oil-change/jeep-2019-cherokee-3.2l-x-ehk
    from the oil to the transmission fluid to the coolant! The previous owner, who I know, ran it into the ground for a year or so without changing a thing so it feels good and the fluids are synthetic.
    next will probably get some new wheels and a new radio with navigation built in.
  17. Aug 26, 2021 at 2:23 PM
    #257
    JJS2
    JJS2 Member
    Jim (Michigan)
    2015 JKU Sport-S Anvil/Black
    Teraflex 2.5 coil lift w/Rancho RS9000s, AEV Bumpers & Tire Carrier, Air Lift bags,
    My '98 XJ was rusting away a year or two after I needed to have the 4.0 rebuilt, so in 2015, I sold it and went to a JKU. But the one best XJ mod that I ever did was putting some Liberty disc brakes on it. Basically four bolts and change the hard brake line from Imperial to Metric. The proportioning valve didn't need to be changed - tracked straight under heavy braking - even in snow pack.
    cpttuna likes this.
  18. Aug 26, 2021 at 7:06 PM
    #258
    cpttuna
    earl
    XJ-98-00-01-and 01
    what year liberty and exactly what parts are needed?
  19. Aug 26, 2021 at 8:40 PM
    #259
    JJS2
    JJS2 Member
    Jim (Michigan)
    I referred to a book by Eric Jaffe, "High Performance Jeep Cherokee XJ Builder's Guide" which gave well-documented step-by-step instructions. (Also a lot of other XJ tips.)
    From a '07 Liberty, I picked the Caliper assemblies, Rotors, and the Mounting/Backing plates. This required pulling the axle shafts.
    Since it was there (and newer), I also took the hard brake line which runs over the axle & differential housing. It's dimensionally identical to the original, but after hours of trial and error, I deduced that the '98 parts have Imperial threads; the Liberty, Metric. So you'd need an adaptor to connect to the hard line to where it runs forward towards the master cylinder. Otherwise, you'd need adaptors at the two caliper connections.
    I started collecting parts on Saturday morning, and if not for the Metric/Imperial issue, I would have been finished that afternoon or evening.
  20. Jul 17, 2022 at 4:25 PM
    #260
    cpttuna
    earl
    XJ-98-00-01-and 01
    Three of my XJ's have had the 2" budget boost installed. MY two 01 models have had the Viper coil mod done on them(no coil rail). All of my jeeps have stainless exhaust. Three of them have my diy driving lights.(these are you standard NAPA 35 watt tractor light with rubber housing modified. You remove the 35 watt sealed beam and replace with a Wagner(#4509) 100 watt seal beam aircraft landing light. These last better than the cheap china chrome models. Also little other things here and there.
