What Battery do I need?
Discussion in 'General Jeep Discussion' started by OFFGRID, May 9, 2017.
  1. May 12, 2017 at 7:06 AM
    #21
    LOL!! Ive actually seen that done!
  2. May 12, 2017 at 5:08 PM
    #22
    dougbbbb
    dougbbbb Well-Known Member
    Ok so it's in. Took a few hours only because I wanted to make sure all the wire harnesses were run tight together. The evap solenoid took the longest because it had to be repositioned and the hoses cut shorter. Overall I would highly recommend this unit.
    Doug
    JKBob 25 and OFFGRID[OP] like this.
  3. May 12, 2017 at 7:13 PM
    #23
    OFFGRID [OP] Well-Known Member
    Wow I like that.
    dougbbbb and JKBob 25 like this.
  4. May 12, 2017 at 7:20 PM
    #24
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    im looking for space in a cherokee,00 even if its just a lawn tractor batt as a backup to get started from a dead main batt. any ideas.
    i love your setup but i got no room!
  5. May 12, 2017 at 7:26 PM
    #25
    You could run the second full size battery in the trunk, or for that batter your put both in the drunk one on each side to redistribute the wait of your vehicle for better balance. this is why many new HP sport cars have theirs in the trunk these days.
  6. May 12, 2017 at 7:36 PM
    #26
    Sweet Doug. I'm going to look into that tray and set up. Nice
    dougbbbb likes this.
