Transmission won't shift after changing conductor plate, filter and fluids
Discussion in 'Grand Cherokee' started by Hexen1095, Oct 15, 2023.
  1. Oct 15, 2023 at 12:31 PM
    Hexen1095
    Hexen1095 [OP] Member
    William
    2005 3.7 granf cherokee lerado
    Replaced conductor plate in transmission. New filter and fluids. Pretty sure I lined the plastic piece correctly . Replaced rear vss. This took care of all the codes I was getting. NOW, it won't shift while driving. No codes. Won't shift manually using the "slap shifter" option. What am I missing
  2. Oct 18, 2023 at 3:28 PM
    Hexen1095
    William
    New codes today. Took it out to warm it up and check fluids. Was alittle low, so added fluid. P0717. All I can find is its the sensor, in the conductor. Any thoughts?
  3. Oct 18, 2023 at 4:03 PM
    Sounds like the sensor.
  4. Oct 18, 2023 at 4:20 PM
    Hexen1095
    William
    I can turn wrenches..not great with electrical. I'll give it a shot. I've seen diagrams around so I'll study up
