Transmission maintenance strategy for longevity
Discussion in 'Grand Cherokee' started by Ragmanx, Jan 30, 2024.
  1. Jan 30, 2024 at 5:30 PM
    Ragmanx
    Ragmanx [OP] Member
    Steve
    2011 Grand Cherokee 2023 Grand Cherokee
    I own a 2011 JGC Limited,. Bought new now has 95K miles now.
    Always serviced, no tick, Beautiful Jeep!
    My goal is to keep it to 150K ++.
    My trans has never been touched, fluid pink, no smell. Sometimes clunks putting when manual shifting between gears.(P R N D).
    I am way over any service interval on the trans. It is w5a580 Trans mission.
    Here is the advice opinions I am seeking;
    1.- Have pan dropped, change filters and add any fluid about 4 qts. BG fluid. $190 by my trusted Mechanic.
    or
    2- Flush trans. No new filters, add MoPar 4+. $350 by Dealer.
    or
    3- Have pan dropped, change filters and add any fluid about 4 qts. $250 by Trans. Shop
    or
    4. Have pan dropped, change filters and add any fluid about 4 qts Aamco fluid by Aamco. $243.
    or
    5. Just leave it be. you think?
    Can't wait to hear your opinions or comments.
    Thank you,
    Steve
  2. Jan 31, 2024 at 2:02 PM
    I'd recommend a drain/fill/filter and no flush. Use Mopar 4+ or OEM specified ATF
    LYFZGOOD, shooter65 and Bob like this.
  3. Jan 31, 2024 at 2:30 PM
    Ragmanx
    Ragmanx [OP] Member
    Steve
    Thank you, that's what I will do.
    aggrex and Bob like this.
  4. Feb 7, 2024 at 3:27 AM
    shooter65
    shooter65 Well-Known Member
    Southwest PA
    2023 Rubicon 4 Door
    The dealer option is to CAUSE problems so they can ding you for a new trans. NEVER let anyone flush your tranny.
    If you can find a shop that will recover your old fluid and put it back in after dropping the pan and replacing the filter, that is best option with 95k miles and no previous service.
