Thoughts on installing an in tank fuel pump?
Discussion in 'CJ' started by MOMark, Aug 11, 2021.
  1. Aug 11, 2021 at 1:55 PM
    MOMark
    MOMark [OP] New Member
    Mark
    1985 Cj7 Laredo
    A/C Fuel injection Replaced a lot of old parts Rebuilt 258
    New to this forum. 1985 Cj7 Laredo. First Jeep, purchased Nov. 2019. I've been working on it ever since. Sometimes it runs, most times it doesn't. Trying to get it to be a daily driver and also take it on trails. Current project is to put an in tank fuel pump on it. Holley strongly suggests doing that and it will also make the fuel pump less vulnerable. Anyone have any suggestions for installing an in tank fuel pump?
  2. Aug 11, 2021 at 8:58 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Assuming you have the Weber carb and a 15 gallon tank Novak has a decent kit that has in-tank pump/sending unit, gasket, frame mounted filter and pressure regulator (carb only uses 3-3.5 psi). They have kits for the 20 & 21 gallon also, so verify your tank size.
    Drop tank and install in place of factory sending unit. You just have to run keyed power to it. Though not required, you can cut the lever off the mechanical pump if it's worn out and clicking on the camshaft.
    Bob and aggrex like this.
  3. Aug 11, 2021 at 9:24 PM
    Groundfault
    Tim
    When you get a chance, post some pictures of the CJ. I always like seeing what people are working on.
