Starter replacement question
Discussion in 'Electrical' started by Qwuark, Dec 4, 2019.
  1. Dec 4, 2019 at 6:00 AM
    Qwuark
    Qwuark [OP] Member
    02 TJ
    1.5" spacers
    Hey there!
    New jeep owner, new DIY mechanic too...
    My starter went out on my manual transmission 2.5l 4cyl 02TJ. I bought a replacement according to the specs from Quadratec. But, the mounts aren't anywhere close. Who knows, maybe my specs are wrong.
    I've uploaded a picture and hoping some expert may be able to help.
    Thanks!
    -Qwuark
  2. Dec 4, 2019 at 7:53 AM
    What starter did you get from Quadratec?
  3. Dec 4, 2019 at 8:10 AM
    Qwuark
    Qwuark [OP] Member
    02 TJ
    1.5" spacers
    I attached a screenshot of the part.
    Thanks for your reply.
  4. Dec 4, 2019 at 8:42 AM
    Interesting. Wonder why the two different starters for the same engine? Different block castings?
    I guess there is something to be said for buying from a local parts store, hopefully this isn't your only vehicle or you are able to buy local to get back on the road and then return the Quadratec starter for a refund.
    Qwuark[OP] likes this.
  5. Dec 4, 2019 at 8:43 AM
    QT is a good company to work with. Let them know about the issue and they should be able to work something out. Perhaps a different part# or motor was used. Check the local Advance or Autozone for the specific starter.
  6. Dec 4, 2019 at 8:52 AM
  7. Dec 4, 2019 at 10:48 AM
    Qwuark
    Qwuark [OP] Member
    02 TJ
    1.5" spacers
    Thanks for all the replies! I'll go to my local parts store with the starter and see if they have a match.
    I thought it was wierd too. The mounting of the starter seems, strange and unsecure. But I'm not not an engineer!
    Again, thanks!
    Billy1234 likes this.
