Spark plug ideas
Discussion in 'Wrangler JK (2007-2017)' started by Billy1234, Jun 29, 2017.
  1. Aug 12, 2017 at 11:51 AM
    #21
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Ment inside
  2. Aug 12, 2017 at 6:37 PM
    #22
    Billy. Remember when you thought you were having an issue with the gas you were using. Well, there's your answer. Those plugs are shit. Produced a very poor spark, hence lousey mpg, get up and go, and over all performance.
    You should have noticed an improvement the first time you turned the key. It's not like you had to break in your plugs to run better. If you still have a misfire. Theres an issue some where. Is your Check Engine light blinking? You still showing a code?
  3. Aug 15, 2017 at 11:34 AM
    #23
    SCSPerformance
    SCSPerformance Member Vendor
    Vin
    If you're still experiencing a miss, it could be the coil that went bad as well.
  4. Aug 15, 2017 at 12:53 PM
    #24
    Billy1234
    William
    1997 XJ 2 door
    None yet
    @JKBob 25 no code but still misfiring just a little bit ganna change the coil pack friday and that should be it
  5. Aug 15, 2017 at 12:53 PM
    #25
    Billy1234
    William
    1997 XJ 2 door
    None yet
