Rocker switch backlights won't turn off
Discussion in 'Wrangler TJ (1996-2006)' started by Kelsouta03, Jun 18, 2024.
  1. Jun 18, 2024 at 7:21 PM
    Kelsouta03
    Kelsouta03 [OP] New Member
    2006 red wrangler tj
    Hello. New to the group. I recently purchased a 2006 TJ and I'm seeing the rocker switch blue backlights won't turn off. Engine is off, doors closed and all lights off except switch back lights. Need help on how to get these to disengage so it doesn't drain the battery. Ty so much.
  2. Jun 18, 2024 at 7:57 PM
    OEM or aftermarket rocker switches? One aftermarket brand, the RC switch panel had rocker switches that stayed on when key was off/out until there was an update. Otherwise the previous owner may not have wired things up correctly or changed something. Contact seller? Low voltage LEDs probably won’t drain the battery for a few days +\~
    LYFZGOOD likes this.
