Reverse vibration/shimee
Discussion in 'CJ' started by MikenSoCo, Mar 29, 2025 at 8:30 PM.
  1. Mar 29, 2025 at 8:30 PM
    MikenSoCo
    MikenSoCo [OP] Member
    Friday
    Mike
    1972 CJ5
    Working on a project ‘72 CJ5…
    Shimees and vibrates in reverse…
    Where to begin?
    Thank you!
    LYFZGOOD likes this.
  2. Mar 30, 2025 at 7:08 PM
  3. Apr 1, 2025 at 2:26 PM
    MikenSoCo
    Friday
    Mike
    1972 CJ5
    Did I miss something?
  4. Apr 1, 2025 at 2:31 PM
    I wanna see the project :boink:
    MikenSoCo[QUOTED][OP] likes this.
  5. Apr 1, 2025 at 6:23 PM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    Does it do it in 2x4, 4x4, or both? Shimee as in front axle like death wobble? My first wild a$$ guess would be front axle U-joints or perhaps pinion bearings. Loose rear axle pinion bearings will make vibration in reverse and should also be present on deceleration driving forward.
    aggrex, JKBob 25 and LYFZGOOD like this.
  6. Apr 2, 2025 at 6:14 AM
    MikenSoCo
    Friday
    Mike
    1972 CJ5
  7. Apr 2, 2025 at 6:19 AM
    MikenSoCo
    Friday
    Mike
    1972 CJ5
  8. Apr 2, 2025 at 9:03 AM
    MTgeezer
    John
    55 CJ 3B
    What engine?
    The usual suspects for shimmy are worn tie rod ends, ball joints, spring shackle/hanger bushings, wheel bearings, improper caster/toe-in, and bad or unbalanced tires. But you experience that shimmy driving forward, usually in the 25-50 mph range, and driving in reverse would be too slow for most of that to have any effect.
    Please post what you discover!
  9. Apr 2, 2025 at 10:33 AM
    MikenSoCo
    Friday
    Mike
    1972 CJ5
    258, I6…
    3 speed manual
    In 2wd, from a stand still, letting the clutch out in reverse, vibrates significantly.
    Ty for your input!
  10. Apr 2, 2025 at 6:38 PM
    MTgeezer
    John
    55 CJ 3B
    If the vibration is all from the rear axle, very likely it is the pinion bearings. Jack the rear axle up and check the movement of the pinion u-joint yoke. There shouldn't be any perceptable movement other than rotational. I can't remember if the 72 models use a crush sleeve to set the pinion preload or it those use the shim packs like the pre72 CJ's. You will need the factory service manual (FSM) to install new bearings and set the preload. The FSM is available on-line here: http://www.earlycj5.com/xf_cj5/index.php?resources/15/history
    Not sure if you can see that/download it without joining the Early CJ5 site but that site is the best source of information on pre 76 CJ's.
