No power after jumping
Discussion in 'General Jeep Discussion' started by Guitarland86, Jul 18, 2017.
  1. Jul 18, 2017 at 8:15 AM
    Guitarland86
    Guitarland86 [OP] New Member
    i had left the keys in the ignition last night and had an almost completely dead battery this morning. i got a jump from a neighbor and power came back for a moment. i turned the key to start the vehicle, it clicked once, and then all power dropped - lights, dash, everything. I'm at a loss. im guessing a battery fuse, but have no clue where to find it. I checked the manual, but didn't see a ''battery fuse" Anybody have a clue as to what happen or what to look at to fix this?
    i had left the sunroof open and it did rain a bit last night. i'm not sure if that could have done some electrical short but i thought it may be pertinent.
  2. Jul 18, 2017 at 8:28 AM
    Battery might be dead beyond being able to be RE charged. If jumped to another vehicle, is everything operational? And welcome to the site!!
  3. Jul 18, 2017 at 8:39 AM
    Guitarland86
    Thanks for having me! unfortunately, no power whatsoever while it is jumped to another vehicle. power only came back when i first hooked them up and then power dropped after turning the key once.
  4. Jul 18, 2017 at 9:18 AM
    I would try swapping with a good battery, and see if the issue is the battery. Easiest thing first. If that's not it, I would check all connected tons, mKing sure connection surfaces are clean with good contact. Then, search for a clown fuse.
  5. Jul 18, 2017 at 3:43 PM
    If I suspect a severely discharged battery or battery with dead cells, try a jump without a direct connection to your battery.
