No pedal 2002 wrangler
Discussion in 'Wrangler TJ (1996-2006)' started by Ckrukjr, Dec 30, 2024.
  1. Dec 30, 2024 at 9:30 AM
    Ckrukjr
    Ckrukjr [OP] New Member
    2002 jeep wrangler
    I have a 2002 Jeep Wrangler. I recently changed all four brakes, both front rotors and replaced the front calipers because the driver’s side was frozen. Since then when the motor is running the wrangler has no pedal, if the car is off everything is fine. I tried bleeding the brakes but that didn’t help. I bought a new master cylinder and 2 new wheel cylinders and that didn’t help either. I’m out of ideas as to what the problem can be. Any suggestions would be greatly appreciated.
    thanks
  2. Dec 30, 2024 at 9:31 PM
    I don't think it has anything to do with your brakes @Ckrukjr . If the engine starts, the engine reves, and you dont move. Could it be possible something got disconnected by accident . Or knocked into Neutral? Just a thought.
  3. Dec 31, 2024 at 3:41 AM
    Ckrukjr
    2002 jeep wrangler
    Hi,
    Sorry, what I meant by no pedal was that the brake pedal goes down to the floor when the engine is running. The jeep moves fine it just doesn’t stop. When the engine is off the brake pedal seems fine.
  4. Dec 31, 2024 at 5:48 AM
    If the MC /ABS wasn’t bled properly as per oem specs it could add onto the problem.
  5. Dec 31, 2024 at 6:13 AM
    Ckrukjr
    2002 jeep wrangler
    Thanks I bled the MC but I didn’t know about the ABS. I’ll have to research it because I’ve never heard of that
