New Member from Idaho
Discussion in 'New Member Introductions' started by Blank, Aug 27, 2022.
  1. Aug 27, 2022 at 8:31 AM
    Blank
    Blank [OP] Member
    Blank
    Nampa, Idaho
    2015 JK 2-Door Tank
    The JK is lifted 2.5 inches, 33" tires and 18" wheels, steel fender mods. Custom front bumper, and roof rack
    Not new to Jeep's, as I have had plenty of them, just new to this Forum. Will have plenty of time to visit. Have had my 2015 JK for a while, and fixed it up for my uses. Had a little money to spend, and just scored another older 1971 CJ-5 to play with. For $1000, I couldn't pass it up. One of those "It was running when it was parked ... years ago!!"
  2. Aug 27, 2022 at 12:53 PM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    Welcome aboard. You scored well on the CJ. I assume the factory 225 and Saginaw manual steering swap? Looks like the rear axle was swapped out at some point too. If it is a 71, that came originally with the flanged axle shafts-the best ever put in any CJ.
  3. Aug 27, 2022 at 1:49 PM
    Blank
    Blank [OP] Member
    Blank
    Nampa, Idaho
    2015 JK 2-Door Tank
    Hi there. Thanks for the welcome. Yes, 225 V-6, headers with shorty mufflers and side pipes. New springs on all four with about 3" lift built in and the EMU greaseable shackles. It has power steering, but not sure about it at all. Will get to spend the next few days crawling all over and under it.
  4. Aug 27, 2022 at 2:27 PM
    Welcome @Blank …that’s an awesome and envious find. Luv CJs and like that blue
  5. Aug 28, 2022 at 1:07 PM
    Blank
    Blank [OP] Member
    Blank
    Nampa, Idaho
    2015 JK 2-Door Tank
    So you're working on your 51 year old Jeep project and you need to pull the seats, and get the gas tank out. How awesome is your day going to be, when your first find in the dirt and debris is that 10MM socket that everybody always loses????? :)
  6. Aug 28, 2022 at 1:52 PM
    MTgeezer
    John
    55 CJ 3B
    As in there are metric bolts on that????
  7. Aug 28, 2022 at 2:24 PM
    When the SAE bolts rust and crumble sometimes the 10mm comes in handy.
  8. Aug 28, 2022 at 5:13 PM
    Blank
    Blank [OP] Member
    Blank
    Nampa, Idaho
    2015 JK 2-Door Tank
    Probably not intentionally, but it took both SAE and Metric, an impact wrench, impact chisel, sawzall, and Makita grinder with cutting disc to get the two seats and tank out today!!!!! :)
  9. Aug 28, 2022 at 7:00 PM
    Jeep4Life
    Jeep4Life Well-Known Member
    2012 Jeep Wrangler Unlimited
    Welcome from Florida!
  10. Sep 1, 2022 at 8:00 AM
    Blank
    Blank [OP] Member
    Blank
    Nampa, Idaho
    2015 JK 2-Door Tank
    Tank cleaned and flushed, new fuel lines and filters, and back in. Headers and mufflers properly mounted with exhaust hangers. Battery pulled out and charging, cleaned out the mess of tangled wires all under the hood. Got the new seats and seat belts back in. Making progress slowly!!
    Jeep4Life, JKBob 25 and aggrex like this.
  11. Sep 11, 2022 at 12:26 PM
    Blank
    Blank [OP] Member
    Blank
    Nampa, Idaho
    2015 JK 2-Door Tank
    Who knew Jeeps were carnivorous? Ouch!!!
    Full set of brakes this week, from master all the way to shoes drums, and wheel cylinders! Then road testing!!
  12. Sep 11, 2022 at 1:08 PM
    Looks like a bunch of $&@%# ouch! What part got you with the V-shaped tear? Must have been quite bloody. Heal well and fast
  13. Sep 11, 2022 at 1:14 PM
    Blank
    Blank [OP] Member
    Blank
    Nampa, Idaho
    2015 JK 2-Door Tank
    Had just installed a new battery, and was on the passenger side. Got tangled up in power cords (I know, put stuff away when done) and took a spill, so grabbed the closest sheetmetal on the side of the body somewhere. Bled about a quarter of a roll of paper towels, then drove to the ER. :)
  14. Sep 11, 2022 at 1:55 PM
    :annoyed:Wow….I’ve been fortunate so far. I’m sure you got Mr Tetanus too
  15. Sep 11, 2022 at 3:27 PM
    Blank
    Blank [OP] Member
    Blank
    Nampa, Idaho
    2015 JK 2-Door Tank
    I travel out of state, and out of country often enough to keep all my shots current. It had been a few years, so we boosted my Tetanus again!!
