New at Jeeps.net
Discussion in 'New Member Introductions' started by Dunk78, Nov 6, 2017.
  1. Nov 6, 2017 at 5:23 AM
    Dunk78
    Dunk78 [OP] New Member
    Tom
    87 YJ
    My most recent purchase is a 87 YJ w/ 4.2, BA10 trans (yuk). This YJ has never seen a winter. The original color was Yellow with Spice interior. It might have been a Islander?? But it was painted green at some point. Glad to be aboard.
  2. Nov 6, 2017 at 5:36 AM
    Welcome, what are your plans for the new acquisition?
  3. Nov 6, 2017 at 5:41 AM
    Dunk78
    Tom
    87 YJ
    The Jeep sat in storage for 7 years before I bought it. I runs real rough. Probably start with a Nutter and see if that helps.
    It needs a lot of attention, valve cover to begin with. I have many ideas so we will see how it all unfolds.
  4. Nov 6, 2017 at 5:58 AM
    That's common on the 4.2/4.0 engine.
    Not sure what a Nutter is, but sounds like a good place to start. ;)
  5. Nov 6, 2017 at 6:46 AM
    Welcome aboard!
  6. Nov 6, 2017 at 7:50 AM
    Nutter =Nutter bypass, or computer delete.
  7. Nov 6, 2017 at 9:11 AM
    Welcome to the site!
  8. Nov 6, 2017 at 9:38 AM
    nut·ter
    ˈnədər/
    noun
    BRITISH informal
    1. a crazy or eccentric person.
    None of my vehicles came equipped with one (see above) so thanks for the clarification.
  9. Nov 6, 2017 at 3:52 PM
    Offroad798
    Offroad798 Well-Known Member
    Florida
    2015 Rubicon
    Welcome from Florida.
  10. Nov 6, 2017 at 4:08 PM
    Welcome! Could be an interesting build. Stored for 7 years is both good and bad for a vehicle. Running rough could be attributed to more factors besides just the nutter.
  11. Nov 6, 2017 at 6:56 PM
    Welcome to the forum Dunk78. Not going to touch the "nutter". Loll. Welcome dude. :wave:
  12. Nov 8, 2017 at 3:19 PM
    Dunk78
    Tom
    87 YJ
    I have been running it a little here and there and it is better +/-. Choke is not working at all though.
  13. Nov 9, 2017 at 7:29 AM
    I've been thinking about your Jeep. It is an 87 so that means it is carberated right? If it set up for 7 years the carburetor seals are shot and it needs to be rebuilt. You will never get it to run right with bad seals in the carb. Also the gas is bad. Drain the tank and refill it with new gas. Start there and see if it is better.
