My passenger door is stuck!
Discussion in 'Cherokee' started by Engir, Jul 9, 2024.
  1. Jul 9, 2024 at 10:03 AM
    Engir
    Engir [OP] 1987 Jeep Cherokee Laredo
    Costa Rica
    none
    I was replacing the door locks on my 87 XJ after installing the lock in the passenger side door I used the key and turned the lock both ways everything seemed fine and closed to door. Now it will not open from the outside or inside, I unhooked the rod to the lock and moved all the rods back and forth and it will not open has anyone had this happen, does anyone know a way to get the door open?
  2. Jul 9, 2024 at 4:15 PM
    I'd pop off the driver-side door panel and observe the door latch mechanism operation. That should give you a clue as to what is not functioning on the passenger-side door/lock/latch
  3. Jul 9, 2024 at 4:31 PM
    Engir
    Costa Rica
    none
    Seriously, how did I replace the lock with the door panel on?
  4. Jul 15, 2024 at 4:30 PM
    Engir
    Costa Rica
    none
    So I got it fixed this is for anyone in the future with an issue like this. In the image below you see a plug behind that is an allen bolt adjustment for the outer door handle. I hooked up the rod and it moves but the door latch does not function so I loosened the Allen and pushed the outer handle I think 3 times and the latch opened, I did it one additional time the latch opened and I tightened to Allen down and the door works perfectly.
  5. Jul 20, 2024 at 11:58 AM
    Engir
    Costa Rica
    none
    I got my T-30, tell me if you can see the issue?
