My $120 CJ7 build
  1. Feb 19, 2023 at 10:55 PM
    #241
    daddyusmaximus
    '79 CJ5
    Been a while, but I finally got back out in the garage for a bit here a week ago, then again today.
    Had to redo the brackets for the stacks. Figured I'd need some thicker steel once the mufflers came in.
    JKBob 25, aggrex and LYFZGOOD like this.
  2. Feb 19, 2023 at 10:59 PM
    #242
    daddyusmaximus
    '79 CJ5
    Got the windshield frame on. It will most likely need to come back off at least once more, but it fits, and looks good with the glass in it.
    Also note there are now roof rack brackets on the hinges. I picked up a used rack from a JK. Just need to cut it down to size.
  3. Feb 20, 2023 at 6:29 AM
    #243
    Great to hear and see you back in the shop
    :cheers: “Git-‘er-Done”
    daddyusmaximus[OP] likes this.
  4. Mar 4, 2023 at 11:25 AM
    #244
    daddyusmaximus
    '79 CJ5
    Did a bit of work on the winch plate today. Wanted the winch low, between the frame rails, behind the front bumper. On an old CJ... that means pushing out the front bumper a few inches. There will be another mount on top for the hole in the top of the frame rail, and another one of those big 3/4" through bolts (each side) where I'm pinching the frame.
    aggrex, LYFZGOOD and JKBob 25 like this.
  5. Mar 22, 2023 at 6:05 AM
    #245
    daddyusmaximus
    '79 CJ5
    Mounted the finished front bumper yesterday. Still have a couple more holes to drill, and paint of course, but it's starting to look like something. The flags are removable, and I'll only run them occasionally. I have reflective stickers made for each. An American flag for one, and an L Troop 3/2 Cav guidon for the other to match up with the bumper numbers I'm using. (VII 2-CAV L-27) This is to represent the very first tank I was ever assigned to at the very first unit I was ever assigned to way back in 1981...
    Yeah, that's me in the driver's hatch... lol.
    This will be my "27" now.
    LYFZGOOD, aggrex and JKBob 25 like this.
  6. Mar 22, 2023 at 6:07 AM
    #246
    daddyusmaximus
    '79 CJ5
    Also did some work on the windshield wipers. The 5 ton wipers are WAY too long for the narrowed and chopped deuce windshield, and had to be shortened, so I used the ends of the CJ7 wipers to do it. This also gets me the ability to use somewhat modern wiper blades.
  7. Mar 27, 2023 at 6:23 PM
    #247
    daddyusmaximus
    '79 CJ5
    On tonight's instalment of build a CJ7 in your garage... we install the running boards.
    Wait... They don't make running boards for CJ7s, just body armor.
    Well, if you're a fat old retired cripple, you're gonna need a way to get up in the thing.
    Measure twice... cut (or drill) once. As you can see by the markings, I caught myself just in time.
    As you can see, I also didn't make sure to have enough of the right size bolts before starting.
    Then I waited til the hardware store was closed before figuring that out...
    Underneath, they go to the body mounts like the ones you can buy.
    Oh, that "Measure twice... cut once" thing? Yeah I wasn't thinking about that when I had the welder fab these up for me. I have to move 2 of the body mounts for the YJ tub, so those 2 are off... lol. More welding to follow I guess. Well, they have to come back off for paint anyhow.
  8. Mar 30, 2023 at 9:23 PM
    #248
    daddyusmaximus
    '79 CJ5
    I'm gonna be needing a bit more to make this a user friendly vehicle as a daily driver for an old cripple, so I took a folding step and mounted it to the driver's side running board. It fold down, and pins in place for me to climb in, then up and out of the way when not needed. Normally these are found on the front bumper of an M54 5 ton truck to allow troops to climb up and perform engine maintenance. Also fabbed up a mount for the 20mm ammo can center console.
    aggrex, JKBob 25 and LYFZGOOD like this.
  9. Apr 8, 2023 at 7:59 PM
    #249
    daddyusmaximus
    '79 CJ5
    I've managed to get a few things done over the last week. I know, it seems to jump around like I'm working with out a plan. That's only because I'm not. I go out to the garage, and it's what can I do (or do I feel like doing) today?
    I managed to change over from the JY strikers to the CJ ones, and check to make sure the doors will work. They do. The fit isn't 100% perfect, but they open, and close. The fun part will be making everything work with the top...
    Also painted the inside of the tub then mounted the 20mm ammo can that will serve as the center console. 2 bolts to a bracket I made, and 2 more at the rear through the floor. I can still cram stuff under it if I want, and I most likely will.
    Holly sniper fuel pump with filters got mounted to the frame in preparation for the running of fuel lines, and wiring harness.
  10. Apr 8, 2023 at 8:14 PM
    #250
    daddyusmaximus
    '79 CJ5
    Then I decided to jump into the wiring harness. Just tired of looking at the box sitting there on the shelf I guess.
    Sure hope I don't run out of Amazon zip-ties... lol. Need a new grommet for the rear of the tub though Tried to use the firewall one Painless includes for the older model Jeeps... different size.
  11. Apr 9, 2023 at 6:48 AM
    #251
    Great job, keep going be fun when you get to jump in and ride!!
  12. Apr 16, 2023 at 8:42 AM
    #252
    daddyusmaximus
    '79 CJ5
    Since I started in on the wiring harness, I figured it was time to get the dash done. Still had some holes to drill for switches, mount the data plates for that military look, and figure out fan / heat controls & the defrost ducts. Still working on how to control the flappers for the heater, but I used CAD (carboard aided design) to make some ducts for where the YJ style defrosters come through the dash. Then they will go to some 900 series 5 ton splitters and (hopefully) onto the windshield good enough to do the job. Not done with the whole dash yet... but a few steps closer.
  13. Apr 16, 2023 at 8:51 AM
    #253
    daddyusmaximus
    '79 CJ5
    Then I got sidetracked, and decided to fix the front fenders where the spot welds were off on the back edges of both inner fenders. You can see from the boogers that my novice welding with my little old 110v flux core welder looks like Ray Charles did it with his feet, but I did manage to stick the metal together. (at least for now) This is why I have enlisted the services of an actual welder for those things when it counts.
    JKBob 25, LYFZGOOD and aggrex like this.
  14. May 15, 2023 at 7:58 PM
    #254
    daddyusmaximus
    '79 CJ5
    Decided it was time to fit the roof rack on. It will require adjusting because it came off a modern Jeep, and light mounting tabs welded on as well. The wife (teacher) had some high school kids over to weld the tabs on the front bar to the roof rack, and grill. I have 3 sets of Rigid pod lights for the roof rack, and a set that will shine out from the where factory turn signals where. Also made up some tabs to go on the front bumper for military turn signals. These kids are just learning, so there boogers aren't any better than mine, but it's practice, and they earned some of their required "government hours" by helping a disabled veteran do some work around the house. Also, it's light mounting tabs, so it's not like there's gonna be any high stress to them. Two helped me on the Jeep, and two more did garden work for the wife. Used the golf cart to take the back section to a local machine shop to be shortened. That welding has to be strong. Lights go on the outside edges, and I kept the center of the rack open so I can carry a canoe.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
