Missing vacuum hose from throttle body
Discussion in 'Wrangler YJ (1986-1995)' started by boucheryj, Jul 11, 2018.
  1. Jul 11, 2018 at 5:59 PM
    boucheryj
    boucheryj [OP] New Member
    sean
    jeep yj
    I just failed a smog test because I was missing a hose from the throttle body. Can anyone tell me what this valve is for?
  2. Jul 12, 2018 at 6:38 AM
    What year is your YJ? 4cyl or 6cyl? Please circle what you want us to see so we are all on the same page.
  3. Jul 12, 2018 at 7:07 AM
    Welcome aboard!
  4. Jul 12, 2018 at 8:20 AM
    some thoughts-
    how does jeep run?
    Did they say open vacuum line- just a visual issue OR
    some issue ie EGR*vacuum missing that would be easy.
    Would putting caps on vacuum connections be an answer? So easy -
    * EVAP, dist, trans, etc
    boucheryj[OP] and aggrex like this.
  5. Jul 12, 2018 at 9:26 AM
    Welcome! I'm a bit in awe that the tech fails the YJ on the smog test and points out the problem on a 23+ year old jeep.
  6. Jul 13, 2018 at 12:18 AM
    boucheryj
    sean
    jeep yj
    The technician didn't even know what the valve was for, and I looked at another yj and it doesn't even have the valve. I think the caps is the best bet.
  7. Jul 13, 2018 at 7:42 AM
    the jeep is running ok - then give the caps a try
    let us know -
