Light install
Discussion in 'Wrangler JK (2007-2017)' started by Billy1234, Aug 12, 2017.
  1. Aug 19, 2017 at 6:47 PM
    #61
    I see a lot of electrical tape splices. You know they make kits for splicing wirers.lol. :stirthepot:. Billy whipping up some wire concoction. :)
    JeepMafiaMama and chris4x4 like this.
  2. Aug 19, 2017 at 7:10 PM
    #62
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Lol its actually together pretty well i just had to wrap it in tape so it dont look so bad with wires hangin all over the place theres a crap ton of wire but it works perfectly now just to install it all. :annoyed::goingcrazy:I :frusty:
  3. Aug 19, 2017 at 7:20 PM
    #63
    I give ya credit dude. What you have been thru trying to get these lights installed. It's obvious you think they would make a great upgrade to your rig. And honestly...I'd like to see how they look on your JKU. Hope it all works out. Was just bustin your balls. I'm sure your rig will look awesome when you get'em wired up. Patience dude. It will work out.
    Billy1234[QUOTED][OP] likes this.
  4. Aug 19, 2017 at 8:18 PM
    #64
    The fuse size in the harness should be plenty. Its good for up to 200 watts. I think you will be running 20-ish
  5. Aug 20, 2017 at 2:47 AM
    #65
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Really at @chris4x4 i think its a 15 amp fuse i believe? And @JKBob 25 i know for a fact that theyll look great on the rig. Worst part is over i already know where to run the wire so it wont get messed up ill post pics as i go along when i install them ill do a step by step thread for them but first if you have a jku plan on 38 feet of wire total lol
  6. Aug 20, 2017 at 6:18 AM
    #66
    Billy1234
    William
    1997 XJ 2 door
    None yet
    The only thing i will have to look out for is when i do the new fenders and fender liners ganna go with metal ones and maybe drill a small hole to pretty much make the lights flush mounts. Ganna be a blast! I kinda love doing this type of stuff i started messing with radio wires when i was like 7 i took apart my radio and made it louder
  7. Aug 20, 2017 at 7:35 AM
    #67
    Yeah, Its rated for 200. 15 amps is more than enough for your set up.
  8. Aug 20, 2017 at 10:03 AM
    #68
    One issue with running a fuse that is too big is that you can have a fire start on you if the fuse does not blow. Just a thought.
  9. Aug 20, 2017 at 10:27 AM
    #69
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Never thought of that!
  10. Aug 20, 2017 at 10:32 AM
    #70
    Maybe he should drop it to a 10 AMP?
  11. Aug 20, 2017 at 1:13 PM
    #71
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Should i just to be safe
  12. Aug 20, 2017 at 3:29 PM
    #72
    Might not be a bad idea
  13. Aug 21, 2017 at 2:45 AM
    #73
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Gotta love fords.....IMG_1478.jpgim actually a big fan of ford well the trucks anyways best work truck ever but this is what happened to my bosses ford well time to find a old dstreet sign
