Just bought the cj5 front end wanders
Discussion in 'CJ' started by Joey454, Jul 5, 2024.
  1. Jul 5, 2024 at 10:18 PM
    Joey454
    Joey454 [OP] New Member
    Joe
    78 cj5v8 33 12.50 15
    Shackles pro comp
    Hello I just bought my. First cj5. 1978 almost stock 33 12.50 15 with pro comp shackles jeep sat for.20 yrs. In a garage changed fluids, added as needed etc.
    Now problem is front end wonders when cruising down Street also when you take off from a stop sign jeep vers to the right along with letting off the gas goes to the right all components are good tie rods ends drag link steering box no play steering coupler has a tiny bit steering coloum none that I have found wheel bearings serviced no play in knuckles no looseness like I said all steering components are good working order.... yes toe is correct tires are good with all new bushings spring and shackle
    ...pulling my hair out....
    Update after carwash found part numbers on springs both are pro comp 2.5 lift with shackles
  2. Jul 8, 2024 at 8:16 PM
    Could be a combination of poor quality parts or poor installation coupled with a 20 yr old dry rot of any rubber/lubed components. Loose steering /wandering that could border on death wobble ain't to be taken lightly. Could start with the simple stuff like alignment, tire condition, psi, worn parts etc
  3. Jul 10, 2024 at 5:15 PM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    Did you check the caster?? Sounds like too little and that could definitely be the result of lift springs and aftermarket shackles.
