Jeep Cherokee xj w/1 tons and 40's
Discussion in 'Cherokee Builds' started by acerwin, Nov 5, 2017.
  1. Mar 29, 2018 at 8:09 PM
    #201
    Nice seats. I think I might need the wide body seats.
    acerwin[OP] and chris4x4 like this.
  2. Mar 31, 2018 at 5:24 PM
    #202
    acerwin
    acerwin [OP] Well-Known Member
    Andrew
    Laurens, SC
    2001 jeep Cherokee xj
    Custom
    Progress pic courteous of Ed since I didn’t take any today. We’ll work on it a little more tomorrow after family time.
    OFFGRID, JKBob 25 and chris4x4 like this.
  3. Mar 31, 2018 at 6:28 PM
    They do look comfortable and a fixed position probably works well for a 6spd MT except during power nap time when the LOML is shopping.
  4. Mar 31, 2018 at 8:00 PM
    #204
    Sweet. Our seats.....umm. your seats came in. Nice dude. Really...:thumbsup:. Nice.
  5. Apr 1, 2018 at 7:45 AM
    #205
    Way cool!
    acerwin[QUOTED][OP] likes this.
  6. Apr 5, 2018 at 1:34 PM
    #206
    acerwin
    Andrew
    Laurens, SC
    Custom
    Painted some armor for the time being.
    D8BF98B9-195F-4F8A-9BA8-3D3267A844DB.jpg 605C59C8-FA55-41DA-832E-FDEECE5EC6CC.jpg
  7. Apr 5, 2018 at 3:29 PM
    #207
    acerwin
    Andrew
    Laurens, SC
    Custom
    Got my seat belts in the other day also.
  8. Apr 6, 2018 at 8:07 PM
    #208
    acerwin
    Andrew
    Laurens, SC
    Custom
    Watched a few videos from YouTube about installing the sye kit. Does that make me an expert now? I sure hope so since I’m going to tackle it this coming weekend.
  9. Apr 9, 2018 at 11:10 AM
    #209
    It isn't that difficult. Watch out for the double stacked needle bearings. They will go all over. I used grease to hold them in place when I put it all back together. While you are in there I would replace the timing chain and check out your Nylon wear points i.e. shift fork ends and make sure the nylon is all intact. When I did my NP208 I found out that Cloye's makes Tcase chains and figured since they make the best timing chains I couldn't go wrong. Have fun.
  10. Apr 10, 2018 at 2:10 PM
    #210
    acerwin
    Andrew
    Laurens, SC
    Custom
    Pulled the tcase today. Went ahead and pressure washed it while I had it out. Going to install the sye kit this week sometime.
  11. Apr 11, 2018 at 7:00 AM
    #211
    I just saw that they make a 4 to 1 low kit for this. Have you thought about installing it while you are in there?
  12. Apr 11, 2018 at 7:17 AM
    #212
    acerwin
    Andrew
    Laurens, SC
    Custom
    Talking about the Tera low kit?
  13. Apr 11, 2018 at 1:45 PM
    #213
    Southeast Overland
    Seneca, South Carolina
    My only piece of advice is to be very care when you remove the oil pump off of the tail housing. You do not want to break the pickup tube. Also, make sure it is attached right when going back together. You will never know it isnt right until you have destroyed every bearing in the case.
    ~Jeff
    acerwin[OP] likes this.
  14. Apr 11, 2018 at 3:21 PM
    #214
    acerwin
    Andrew
    Laurens, SC
    Custom
    Sweet thanks for the advice.
  15. Apr 11, 2018 at 7:28 PM
    #215
    Ok....you guys have gone far into shit I have no input on. But, I'm learning and startin to figure this shit out. Thanks guys.
    @acerwin . :thumbsup:. Sweet thread.
  16. Apr 11, 2018 at 7:41 PM
    #216
    Yes I think it was the Tera low. Nevermind. That is only making it available to have a 2wd factory low. I thought I read somewhere that someone made a 4:1 for the NP231. I will keep looking and get back to you on what I find.
  17. Apr 11, 2018 at 10:38 PM
    #217
    acerwin
    Andrew
    Laurens, SC
    Custom
    From what I’ve read they’ve stopping making thatbkit. It was messing up from the get go and whoever bought one they’ve stop replacing them. I might just get a atlas later down the road when this setup stops working or I want more out of it.
  18. Apr 12, 2018 at 2:06 AM
    #218
    acerwin
    Andrew
    Laurens, SC
    Custom
    Since I got the tcase out figured I’ll get a Novak 4WD shifter cable. The stock one can bind up and cause problems and not want to shift easily. Being that the Jeep is 17 years old why not just go ahead and upgrade it. 6EE19D45-DB97-4730-8441-2A8813030BC9.jpg
  19. Apr 12, 2018 at 7:43 AM
    #219
    I used this one from Novak and it worked great. [​IMG]
  20. Apr 12, 2018 at 9:02 AM
    #220
    Southeast Overland
    I second that, I run this in my YJ and it is one of the best mods I have done to it.
    ~Jeff
