Interior Door foam dent
Discussion in 'Wrangler JL (2018+)' started by tjdiscenza, Aug 8, 2019.
  1. Aug 8, 2019 at 7:25 AM
    tjdiscenza
    tjdiscenza [OP] New Member
    tj
    2018 JL Sahara 4door 4 cycle
    Recently took my doors off and had them leaning on each other. Appears one a piece was resting on the interior (see pic) and dented the foam. It's been two days and the foam, while recovering/bouncing back anywhere else you press with your thumb around the area hasn't recovered in this particular spot.
    Any suggestions how to fix?
  2. Aug 8, 2019 at 8:41 AM
    Welcome @tjdiscenza ...Sometimes a few days in the sun might do the trick. With a bit of work if the hard plastic is dented to press from behind. Otherwise leave it alone and it may go away or be forgotten. It's a jeep thing :)
  3. Aug 8, 2019 at 10:33 AM
    tjdiscenza
    tj
    Wife’s ready to murder me. Doesn’t understand that dents and dings give Jeeps character .....
  4. Aug 9, 2019 at 2:14 PM
    Applying heat with a hair dryer could help. My Wife has been ready to murder me for the past 40 years.
