Heater blower
Discussion in 'Cherokee' started by Kkoelliker, Jan 17, 2017.
  1. Jan 17, 2017 at 1:42 PM
    Kkoelliker
    Kkoelliker [OP] New Member
    2008 jeep grand cherokee
    so my fan would only seem to work at the high speed. I replaced the heater blower resistor and now it will only kick on after driving for 5-10 minutes. Any ideas what is going on?
  2. Jan 17, 2017 at 4:44 PM
    C2T
    C2T Well-Known Member
    Richard
    Helena, Montana
    Jeep
    Do you have the manual controls or the automatic temperature controls?? If you have the automatic temp controls and the fan control (the control on the left side) is set to AUTO, it will not come on until the system heats up. It is simply kind enough not to blow cold air on you. Could this be part of the issue? Sure sounds right.
  3. Jan 17, 2017 at 8:42 PM
    Kkoelliker
    It's manual. Seems to be working fine right now. I replaced the resistor today.
    I'll update tomorrow morning. the symtoms according to what most have told me including those that are in the repair biz were certain that was the problem. We'll see. Thanks for the response.
  4. Jan 18, 2017 at 7:33 AM
    Kkoelliker
    started it up fan worked fine. 1/2 later to start up again, nothing
  5. Jan 18, 2017 at 6:06 PM
    C2T
    Richard
    Helena, Montana
    Jeep
    I assume you have done the wiggle test in the wires around the motor right? Other than that...I got nothing. :)
