Hard top vs Soft top... what are the advantages disadvantages?
Discussion in 'New Member Introductions' started by Erin505, Mar 17, 2017.
  1. Mar 17, 2017 at 3:27 PM
    Erin505
    Erin505 [OP] Member
    Erin
    About to buy my first Jeep next week!
    I'm going to buy my first Jeep tomorrow and was set on the soft top, but the dealer is trying to talk me into the hard top telling me it's a better fit for me. I'm a single mom and not sure how heavy the tops are, but would assume pretty heavy. He said the 2017 Jeeps tops come in 2 parts. I'm clueless. Any thoughts or suggestions???
  2. Mar 17, 2017 at 9:02 PM
    I went with the hard top, as its a 3 piece, and the 2 front pieces are easily removable. I only ever take the fronts off anyway.
    Erin505[OP] likes this.
  3. Mar 18, 2017 at 4:42 AM
    jharris3
    jharris3 Well-Known Member
    2011 Jeep Wrangler unlimited
    I love the hardtops... my crazy thinking is it's safer...vinyl can be slashed...lol... I would hope that people wouldn't do that but ya never know...and the I'm nut sure if this is what it's called but the T tops come off easily and it's AWESOME for spring and summer
  4. Mar 18, 2017 at 7:58 AM
    KenLyns
    KenLyns 8-in. Third Member
    Jeep Compass 4x4
    Rental
    Personally I would go with the hard top. The vinyl top flutters on the road when you pass a semi. The soft plastic windows are hard to see out of, especially in the rain.
    Ask the salesman to demonstrate removing the two front pieces. The rear section is heavy though: with glass, hardware, and wiring, it weighs 80 lb on the two door, and 95 lb on the four-door (source). If you don't have a helper, there are hoists that can be installed if you have a garage, e.g. https://www.quadratec.com/categories/jeep_hardtops/hardtop_hoists
    jharris3 and Erin505[QUOTED][OP] like this.
  5. Mar 18, 2017 at 8:15 AM
    This is my second Wrangler with the hard top. Better in the winter and much better when parking in questionable areas. The hard top is nearly as secure as a "regular" non-convertible vehicle. Newer JK freedom tops are modern day T-tops which means light-weight and easy to remove. The freedom tops are a bit bulky to store but one can get creative. Soft tops are fun and easier to get "naked" but not secure as they are easily opened by unclipping or by force with a sharp object. When I remove the hard top I treat the JK like a soft top or no top = don't bother locking the doors and keep nothing valuable in the Jeep unsecured. I like the Tuffy or Besttop branded steel enclosures which function like a "regular" trunk. It is best to have at least two people to remove the hard top because its just too risky to drop this top! The hard top is awkward to lift alone, eight bolts to remove and not very heavy with two people. Once any top is removed, the dynamics, feel and looks of the JK change dramatically!
    jharris3 and Erin505[OP] like this.
  6. Mar 18, 2017 at 1:44 PM
    Erin505
    Erin505 [OP] Member
    Erin
    Thanks everyone for your comments and suggestions!!! Went with the hardtop after reading your advice and trying the two out today. SO VERY EXCITED to be part of the Jeep family!!!!!
