Grinding sound in 4WD
Discussion in 'Cherokee' started by Cobrajetken, Feb 26, 2017.
  1. Mar 10, 2017 at 9:48 AM
    #21
    I believe it is a DANA 30
  2. May 19, 2017 at 9:30 PM
    #22
    cjsdad
    cjsdad Member
    Dailey
    albuquerque, NM
    1998 Cherokee Laredo
    No mods yet...
    I am new to the late model Cherokee so forgive me if this is completely wrong, but doesn't the front diff have CAD (Center Axle Disconnect), a vacuum controlled collar that engages the front axle when in 4X4? I have owned an 87 Cherokee, an '85 Dodge W150, and a '95 Dodge Ram 2500 that all had the vacuum actuator on the front diff. It is on the driver's side where your noise is coming from. If your 4X4 lever is not adjusted right, it may not be providing enough vacuum to engage the collar that locks the axle together. If that is the problem, it would make a terrible racket with the transfer case in 4X4 but the axle collar not engaged. Just a thought.
  3. May 21, 2017 at 6:13 AM
    #23
    Cobrajetken, Did you ever figure out the grinding issue?
  4. May 21, 2017 at 7:01 PM
    #24
    I became a member here after this thread started. Picked it up recently. A very interesting read.
    I'd like to know the outcome too. Never know....i may have this issue at some point too.
