Fixing front end nose dive due to heavy bumper?
Discussion in 'Wrangler JK (2007-2017)' started by K6puppy, Apr 9, 2017.
  1. Apr 9, 2017 at 8:09 AM
    K6puppy
    K6puppy [OP] Well-Known Member
    Jay
    Arizonia
    2014 Jeep wrangler unlimited wellys wheeler Black
    xrc front bumper 12000 pound badlands winch 6 pod lights fender flares kc headlight 285/70/17 tires 2 inch leveling kit bushwhacker air snorkel k/N intake rough country duuel steering stabilizer kit
    Hi does anyone on the forum know how to fix the nose dive due to extra weight in the front of the jeep. I have an xrc metal bumper winch. I guess its about 300 pounds. I could use some help on this...
  2. Apr 9, 2017 at 9:07 AM
    If your weight numbers are correct for the front XRC then theres the problem. Heavy metal bumper design coupled with a heavy winch and/or bull bar can overwhelm the stock springs causing sag and poor handling. One could install stronger springs but a bumper diet should be easier. I would test the issue with the XRC off to confirm. I think the XRC is 180 lb which is still quite hefty.
  3. Apr 9, 2017 at 9:16 AM
    K6puppy
    Jay
    Arizonia
    want to put in lift had jeep 3 weeks has a 2 in block leveling kit what I am asking to keep level when changing springs should I get front springs about 1 inch higher to compensate for nose dive yes I have factory springs
  4. Apr 11, 2017 at 12:22 PM
    I found a short article about spring sag and weight written by the tech department at Teraflex. It states that you have to add to the lift what you are sagging. Basically if you want a 2.5 in lift, and the added weight of your bumper and winch are dropping you 1.5 inches, then you would want a 4 in lift. Read the article and see if you understand it the same way I do. You would probably do well with a 3-3.5 in lift.
    https://teraflex.com/news_items/5578afdf3de0f80055a5d1e3
  5. Apr 11, 2017 at 12:26 PM
    K6puppy
    Jay
    Arizonia
    Thanks for help
  6. Apr 11, 2017 at 12:34 PM
    K6 based on the article we Jeepers continuously add more and more weight to the JK and expect it to perform. I would consider a lighter bumper winch combo to avoid longer stiffer springs to accomodate 200-300 lbs out there upfront especially on a daily driver. Now if it was a spec-ed out special purpose vehicle driven on weekends that had to have these heavy components then it makes sense to me to upgrade the suspension. Just my 2 cents
  7. Apr 12, 2017 at 10:22 PM
    K6puppy
    Jay
    Arizonia
    For any one who wants to know how to fix I am putting a 3 inch front spring and a 2.5 spring rear I am going with teraflex it will sit level at a 3 inch lift teraflex runs bigger teraflex has a few videos on springs if considering lift watch videos on spring sag and the one on difference of types of springs and teraflex staff very helpful
  8. Apr 14, 2017 at 6:51 PM
    Awesome read. Thanks guys. You just learned me something.
  9. Apr 18, 2017 at 10:05 PM
    K6puppy
    Jay
    Arizonia
    I actually went with rubicon express lift kit 2.5 and rock crawler adujustable track bar in front will get next Monday and install next weekend
