CSUVIPER's Wifes 2018 Wrangler JL Rubicon
Discussion in 'Wrangler JL Builds (2018+)' started by csuviper, Jul 3, 2018.
  1. Oct 15, 2018 at 7:16 PM
    #81
    No...Will not change the ride. Your just installing rubber spaces above stock springs. I have Superlifts 2 inch pucks. Not sure if they make them for JLs yet. Also. Once you lift it. Gonna have to make other changes as well. Track bar and control arm issues if you don't. I don't know enough about JLs to point you in the right direction as of now. I need to do some research on that Jeep.
  2. Oct 17, 2018 at 9:59 AM
    #82
    csuviper
    csuviper [OP] Tundra Guy Moderator
    Brian
    Colorado
    18 Jeep Wrangler JL Rubicon
    Will be mostly stock
    Rough Country 2.5" spacer lift = $179.95
    Pro Comp 2" lift kit = $223.99
    Pro Comp 2" lift kit with shock extensions = $299.99
    Rubicon Express 2" lift kit = $299.99
    Rubicon Express 2" lift kit = $399.99
    Teraflex 1.5" spacer lift = 160.99
    Teraflex 1.5" lift with falcon bump stops = $260.99
    JKS Adjustable coil spacer 1" to 3.5" lift = $280
    Superlift 2.5" lift kit = $399.99
    Zone 2" lift kit = $359.95
    Tough Country 2" lift kit = $168.89
    *states new shocks are required
    Fabtec 3" lift kit = $593.10
  3. Oct 17, 2018 at 1:13 PM
    #83
    Dont forget the track bar. Best to get an adjustable one, rather than a relocation bracket.
  4. Oct 19, 2018 at 1:42 PM
    #84
    csuviper
    Brian
    Colorado
    None of the lower cost kits mention anything about the track bar????
  5. Oct 20, 2018 at 8:43 AM
    #85
    When you lift, the trac bar shifts the alignment.
  6. Oct 20, 2018 at 1:45 PM
    #86
    Partly why they are referred to as lower cost kits. You can upgrade the basic kits during the build or when the funds allow.
