Coolant overflow tank hose size
Discussion in 'Wrangler YJ (1986-1995)' started by SrdjanDV, May 14, 2020.
  1. May 14, 2020 at 7:28 AM
    SrdjanDV
    SrdjanDV [OP] Active Member
    Srdjan
    Hi Guys;
    Hope you all are fine, can anyone help me with this, what is the size (inner and outer diameter) of the coolant overflow tank hose, which connects the overflow tank with the radiator in a 1991 and up, wrangler yj??
    Thanks!!
  2. May 14, 2020 at 9:25 AM
    Local auto parts store should be able to hook you up. The rubber hose should be able to accommodate small variation. Lost my YJ years ago otherwise I’d go measure it.
  3. May 14, 2020 at 10:38 AM
    SrdjanDV
    Srdjan
    Thanks anyway.
  4. May 23, 2020 at 9:37 AM
    USMC Lifer
    USMC Lifer Member
    1995 YJ
    Pro Comp 3/5 in spring lift, new Novak AX15 5sp, SYE from Adams, All new brakes from Power Stop, All new front end parts ie. ball joint tie rode ends
    It is over all approx. 4 ft 3 in. OD = 12.5mm an d ID is approx 8mm
  5. May 23, 2020 at 9:18 PM
    I would think a vacuum hose of that diameter would do the trick. Available at an auto parts store.
  6. May 25, 2020 at 12:28 PM
    SrdjanDV
    Srdjan
    Thank you very much for the information, "Semper Fi"
