CHIRPING and BRAKE PEDAL SQUEAK
Discussion in 'Wrangler JK (2007-2017)' started by kyldrn, Sep 9, 2017.
  1. Sep 9, 2017 at 4:15 AM
    kyldrn
    kyldrn [OP] Member
    07 Green Wrangler Sahara
    I have a "chirping" sound coming from my rear passenger tire and I cannot figure out what it is. My brake pedal also squeaks whenever I press down on it. Anyone else have these problems or know of any solutions?
    (2012 JKUS)
  2. Sep 9, 2017 at 12:02 PM
    Just a couple of ideas: parking brake adjustment, pad wear indicator, lube back of pads anti-squeal/chatter, caliper "tuneup", and rusty dust shield.
  3. Sep 9, 2017 at 4:26 PM
    My brake peddle squeaked like mad on my jeep. Under the dash, you will see a "plunger" that the brake pushes against. It has a rubber seal around it. I squirted some lube in it, and it has been silent since. Not sure about the rear.
    kyldrn[OP] and JKBob 25 like this.
