Cause of smoke from under the hood?
Discussion in 'Cherokee' started by Countrygirl15, Apr 10, 2019.
  1. Apr 16, 2019 at 9:53 AM
    #21
    Jeep4Life
    Jeep4Life Well-Known Member
    2012 Jeep Wrangler Unlimited
    Glad you got it fixed and up and running. I had a radiator leak in past on a different Jeep('98). Flushed the radiator and added a radiator fluid with a sealer which made it last a couple more weeks but then leak was back again. So ultimately the only fix is to change out the radiator which is what I ended up doing the 2nd time.
    And welcome from Florida.
  2. Apr 19, 2019 at 5:35 AM
    #22
    Countrygirl15
    Countrygirl15 [OP] Member
    Melissa
    2002 Jeep Grand Cherokee laredo
    I am up and running not only did I replace the radiator. I had to replace the alternator and battery!
    Jeep4Life likes this.
  3. Apr 19, 2019 at 5:51 AM
    #23
    Countrygirl15
    Melissa
    Ok so I have a new question... my overhead console isn’t working and ideas why? It’s not a fuse already checked that.
  4. Apr 19, 2019 at 9:16 AM
    #24
    Jeep4Life
    Check the bulb. May just be as easy as replacing it?
