Can I run 15" wheels on my Willy's?
Discussion in 'Wrangler JK (2007-2017)' started by HotRodN, Jan 26, 2018.
  1. Feb 7, 2018 at 7:09 PM
    #21
    As Jeff said, "Plies" are only for a bias ply tire. Personally, I prefer, and currently run, C load rated tires. I never run a higher pressure than 40 psi (35 actually), nor any real loads, and I like a little softer sidewall (not sure if load rating affects this), so a D or E range tire is wasted for my needs.
    JKBob 25[QUOTED] likes this.
  2. Feb 7, 2018 at 8:02 PM
    #22
    boondoc89 Well-Known Member
    I have E rated tires on my rig. And here's why... E rated tired are really meant for trucks that are towing shit therefore needing a stronger sidewall. I don't tow anything with my jeep but I like a little stiffer sidewall just for strength against punctures on the trail. But even then shit still happens when you party naked
  3. Feb 8, 2018 at 12:08 AM
    #23
    HardHat420
    HardHat420 Well-Known Member
    14 jku sport
    Sounds like they'r finally making lower load ranges in 17.
    In 2013 I was looking for a load range C (6 ply) for my 4runner and there were only 3 options at the time and only a handful in D rated.
    Originally I wanted 15s for the 4runner but it has to be 17 or greater on that rig.
    Ended up with maxxis buckshot 2s and loved them. I put then on the jeep after the 4runner and they did great.
    That is until they got smoked by the the larger sidewall when I went down to 15s.
    IMO a 32x17 and a 35x15 feel very similar while driving and braking. The difference is very negligible. But the benefits of having 15s kickass off-road.
  4. Feb 8, 2018 at 9:02 AM
    #24
    For every benefit there is a sacrifice and visa versa.
    JKBob 25, chris4x4 and boondoc89 like this.
  5. Feb 9, 2018 at 10:26 AM
    #25
    HardHat420
    14 jku sport
    Knuckle and tie rod ends.
  6. Feb 9, 2018 at 11:05 AM
    #26
    Blue Baby Sound
    Jeff
    Build threads in sig
    There are ways to make anything work, and then there are best practices. The way to make a 15" wheel work is with extremely low backspacing (like you pictured). The down side to that is horrible scrub radius which results in extreme ball joint and unit bearing wear. Anytime we change BS for wheel fitment it affects the scrub radius, but there has to be a balance in there somewhere.
    If your Jeep is not a DD, no problem. But those of us that have to drive ours every day should keep these things in mind. Again, can it be done or should it be done.
    Pic below is a 17x9 wheel with 3.75" BS, you can see how close an upgraded tie rod end comes to it.
  7. Feb 9, 2018 at 11:21 AM
    #27
    Man....I can only imagine the moment loading on those poor bearings.
    JKBob 25, aggrex and Blue Baby Sound like this.
  8. Feb 9, 2018 at 11:48 AM
    #28
    That's some beefy tie-rod and knuckles in that pic of your TF axle.
  9. Feb 9, 2018 at 12:59 PM
    #29
    I'm drooling over the flag on it....
  10. Feb 9, 2018 at 1:03 PM
    #30
    Blue Baby Sound
    Jeff
    The 1 1/2 ton ends on the steersmarts stuff are some of the biggest I've seen. Great company if you're ever in the market!!
    JKBob 25, aggrex[QUOTED] and chris4x4 like this.
  11. Feb 9, 2018 at 1:47 PM
    #31
    Yea that's pretty awesome
  12. Feb 9, 2018 at 6:57 PM
    #32
    @Blue Baby Sound. Awesome info on the scrub radius. I remember you posting on that in the past. My first thought on hardhats post. Holy crap. How long will his ball joints last. Anyway.
    I'm looking at upgrading tie rod and drag link. And I also remember your post while you were building your Wife's rig. While searching tie rods. I found the Steer Smarts Yeti. Again, remembering your post. But I was curious as to your experience with it. Any issues with it good bad and indifferent. Also. Do you recommend replacing any thing else along with THAT tie rod? Im also looking at TeraFlex's HD tie rod and drag link. I know as a DD. I really don't need them. But I do plan on hitting up some trails this year. Just want the best under my Jeep. Thanks.
  13. Feb 10, 2018 at 6:23 AM
    #33
    Blue Baby Sound
    Jeff
    Our '14 has about 75k miles, all on 37s. A couple of years ago when I started researching tie rods for that Jeep I decided on steersmarts. So I had 2 years of pretty heavy beating on their tie/rod drag link combo when we started the wife's build. The wife's won't see a lot of action on the rocks, but mine does. It's taken everything I've given it.
    The only downside is their size, they're huge!! It takes a bit on the install to get all the bolts in the right place so there's no rubbing when stuffed.
    I haven't tried the TF, so I can't offer any experience on it.
    We've been busy on the wife's build lately, but here's a few shots of the '14 from the last year.
  14. Feb 10, 2018 at 8:10 AM
    #34
    Nice video! Just as impressive as the Super bowl JL traversing the rocks and water
    JKBob 25 and Blue Baby Sound like this.
  15. Feb 10, 2018 at 12:41 PM
    #35
    Blue Baby Sound
    Jeff
    LOL, dude in that commercial is a lot more liberal with the skinny pedal than I am!!
  16. Feb 10, 2018 at 6:56 PM
    #36
    Awesome. Thank you very much Jeff @Blue Baby Sound. Have some cash to save up. So I have a little time to decide. I really like that Yeti set up. If I decide to go with that set up. You have any issues takin a road trip to NJ to help me install them??? Beers on me. Lol. Thanks again for your info. Much appreciated Jeff.
  17. Feb 11, 2018 at 5:46 PM
    #37
    Blue Baby Sound
    Jeff
    Tempting .... :)
  18. Feb 13, 2018 at 9:33 PM
    #38
    HardHat420
    14 jku sport
    I'm cool with that.
    Nice setup!
  19. Feb 13, 2018 at 9:37 PM
    #39
    HardHat420
    14 jku sport
    This video is freakin A-mazing. Looks like something at an amusement or water park.
  20. Feb 13, 2018 at 9:41 PM
    #40
    HardHat420
    14 jku sport
    Scrub radius shmadius. Doesn't matter. My jeep didn't flex nowhere near as good as it does now with the wider stance. Additionally it feels even better on streets and highways now.
    Watch "Jeep jk with 35s and 6 inch lift" on YouTube
    https://youtu.be/Ze4PK2IpWGo
