Bluetooth Speaker Install in Older Jeep
Discussion in 'CJ' started by Cheftao, Apr 8, 2020.
  1. Apr 8, 2020 at 2:47 PM
    Cheftao
    Cheftao [OP] Active Member
    Thomas
    1966 CJ 5 with V6 Dauntless
    2 inch lift kit
    I am fast approaching the depiction whether or not to install a stereo in the Jeep. I am an avid music lover/musician and MUST have music. The question I have is should I install the traditional hard wired stereo OR can I skip that and install some marine grade wireless Bluetooth speakers that could install on the roll bar with no wires? I assume the 2 or 4 speakers(or speaker bar) will both operate on the same channel thus connecting and playing the same song. ANy thoughts and or experiences? Thanks everyone.
  2. Apr 11, 2020 at 7:18 AM
    I dont know much about audio installations, but I want to see what others say.
  3. Apr 13, 2020 at 4:18 PM
    Well, it is a old noisy smelly Jeep after all. If you add an expensive high quality stereo, it will be an old noisy smelly Jeep with a stereo.
  4. Apr 13, 2020 at 7:45 PM
    Check out crutchfield.com for info on radios and speakers that can meet your needs for modern audio with BT, apple/android play etc. They specialize in DIY installations of components that fit with all the necessary connectors, brackets, trim plates and more. Now in your particular situation (old good jeep) BT speaker boxes (marine grade or waterproof) make sense.
  5. Apr 13, 2020 at 8:43 PM
    SMH!
  6. Apr 14, 2020 at 7:52 AM
    Cheftao
    Thomas
    2 inch lift kit
    Hey agreed, I emailed them a couple of days ago but no answer yet. Ill give them a call and see what they think. I’m sorta surprised that no one has heard of a wireless speaker installed in a Jeep. Seems like a really good idea but I am probably missing a detail or two as to why is not possible or functional...
  7. Apr 22, 2020 at 11:15 AM
    Cheftao
    Thomas
    2 inch lift kit
    UPDATE: I spoke at length with a very knowledgeable Crutchfield tech named Diane who is great. What I am looking for does not exist yet so I have to move to plan B which is a Bluetooth amp with hard wired speakers and hot wire to battery/fuse box. The 66 CJ 5 does not have a fuse box but I am addding one so I can easily wire in after market items such as stereo/CB radio and light bar.
  8. Apr 22, 2020 at 1:15 PM
    In addition to the fuse box I’d recommend a circuit breaker from the hard-wired 12V source to the individual fused new accessories.
  9. Apr 24, 2020 at 6:07 AM
    Cheftao
    Thomas
    2 inch lift kit
    Hey agree, thanks again for all the great suggestions. Yes my plan is to do just that based on your recommendation. Thanks again this advice really helps “flatten the learning curve”.
