Banks Ram-Air
Discussion in 'Wrangler JK (2007-2017)' started by Rogue26, Sep 6, 2017.
  1. Sep 11, 2017 at 9:06 AM
    #21
    Nabdo
    Nabdo Active Member
    Nick
    '17 JKU Rubicon
    $100 is a great deal for that. I was thinking of buying the Banks stinger system with the exhaust but I decided to wait and get the Injen intake instead so I can add a snorkel to it later. As far as cleaning an oiled air filter goes, use a garden hose and wash it from the inside out at low pressure let it air dry and then apply the oil and let it sit for 20min before putting it back in.
  2. Sep 11, 2017 at 7:03 PM
    #22
    I ran an Air Raid system in my XJ. I noticed the higher Temps immediately. Figured it was just a side effect. And, had an overheating issue with it sitting in traffic. If imsaved the OEM box, i would have reinstalled it. After doing some research, and posting the question here on CAI systems. I choose to keep my JK stock.
  3. Sep 11, 2017 at 7:58 PM
    #23
    Rogue26
    Rogue26 [OP] Well-Known Member
    Brian
    2013 JKU
    Front/Rear bumpers, 10k Smittybilt Winch, Bussman Auxiliary Power Panel, Joying Android Stereo, Cibie H4 Headlight Upgrade, 50” Lightbar. Planning: 2.5” TeraflexLift, 35” KO2’s, Regear from 3.21 to 4.56’s
    So what is would a relatively normal temperature be? I really wish that I would have trended it beforehand but I didn’t really think about it.
    This is during a 5 minute warm up period in my driveway. Left is intake temperature and right is ambient air tempature
    This is initial drive on a back road averaging 30-45mph
    His is the return trip home after 10 minutes approximately 60-65mph
  4. Sep 11, 2017 at 8:19 PM
    #24
    Based on what thermostat your running. You should be under 200 or better. A 180, you should be around that. The cooler the motor runs. The better.
    Back in the day. Guys would run 180s in the summer. 210s in the winter. These days. Honestly. Run what Jeep says you should run. And based on your model Jeep. Follow the manual. They know better than we do.
  5. Sep 11, 2017 at 8:25 PM
    #25
    Those look similar to the temps I was getting. The theory my friends and I have, is that location has a "Dead Spot" of air circulation, in which there isnt really any "Ram Air" effect, but pulls the heated air that goes thru the radiator and stagnates behind the headlight area. Factory set up pulls from the fender area, where the hood meets the body, thus getting cooler air.?. Now.....we haven't gotten any hard data to back this up, so take it for its worth. I ran it for a while, but seemed to lose a MPG or two, and along with the loud sound, I swapped the OEM set up back in, and haven't looked back. It sounded great, but when on steep grades climbs, and screwing around, it was a little annoying after a while for me. BUT....I'm old........and........listen to unique music.
  6. Sep 11, 2017 at 8:39 PM
    #26
    Actually, Modern engines run best at hotter temps. With the onset of computer monitoring and such, you can run an engine a little hotter, and get better efficiency without adverse issues.
    JKBob 25[QUOTED] likes this.
  7. Sep 11, 2017 at 8:42 PM
    #27
    Huh....what did you just say. :coffee:.
    Lolll. It's all good. Sorry Chris....you left me no choice. Lollll. But.....what he said. He knows his shit. :)
    chris4x4[QUOTED] likes this.
  8. Sep 11, 2017 at 8:48 PM
    #28
    Really??? I'm an old school guy. We use to dump ice into our motor compartments. We had ice buckets. Now your dumping this on me. Really.?? Where was I? What did I miss??..ok.... there was that time in the 80s I missed, And we'll leave it at that. Lolll
  9. Sep 11, 2017 at 8:56 PM
    #29
    Rogue26
    Brian
    2013 JKU
    I will keep watching the temps for a while and I might reinstall the OEM intake and compare it for a little bit.
    A 5 degree difference between intake temp and ambient doesn’t seem so bad at 40 and I averages about a 25 degree difference at higher speed. Picture 3 was the highest I saw.
    Overall I really like the sound that the banks puts out but, now it really has wondering if there is a temperature difference.
  10. Sep 11, 2017 at 9:00 PM
    #30
    Yes! Run for a week, and note temps, then swap, and do the same thing. Keep us posted!
  11. Sep 12, 2017 at 7:02 AM
    #31
    Yup, if the engine does not get up to proper operating temps (or the computer does not see proper temp) the computer will keep the engine in an "open loop" and will run rich.
    But that time it was chemically induced...
    JKBob 25[QUOTED] and chris4x4 like this.
  12. Sep 12, 2017 at 7:18 AM
    #32
    I mean........define "chemically".......
  13. Sep 12, 2017 at 6:10 PM
    #33
    No..no..no. No chemicals. Mostly herbal. Lol..:rasta:
