Bad words were said........
Discussion in 'General Jeep Discussion' started by The4x4Guys, Apr 25, 2019.
  1. May 1, 2019 at 1:11 PM
    #41
    morzh
    morzh Well-Known Member
    Mike
    Jackson NJ
    Jeep Grand Cherokee, Wrangler JLRU.
    Then.....if you have it in you, drill the hole as large as possible, then use the Dremel to cut the remaining shell in 3 pieces, 120 degree each. They should just fall out with little help. Two pieces also possible but 3 is better. The cut itself should be fairly good, like 1/16" or a bit more.
  2. May 3, 2019 at 5:39 AM
    #42
    Damn I wish you were closer I have 3 welders and 2 oxy/act setups
