Are Jeep Wranglers supposed to be rough rides?
Discussion in 'Wrangler TJ (1996-2006)' started by Johnny Jeeper, Dec 27, 2017.
  1. Dec 27, 2017 at 6:04 AM
    Johnny Jeeper
    Johnny Jeeper [OP] New Member
    John
    2000 Green Wrangler Sport
    Excuse the ignornance..... Are Jeep Wranglers supposed to be rough rides?
  2. Dec 27, 2017 at 6:22 AM
    welcome to the site! Ride quality is dictated by the spring rate, tire pressure, and such. Is your Jeep lifted?
    DustStorm4x4 likes this.
  3. Dec 27, 2017 at 6:23 AM
    Rc Jeep
    Rc Jeep Well-Known Member
    Ryan
    '16 Rubicon
    JKBob 25 and JeepMafiaMama like this.
  4. Dec 27, 2017 at 6:24 AM
    Welcome! During your initial test drive it should have been very apparent LoL. Actually I find the ride quite invigorating during the morning commute to work as compared to consumers report whining and complaining.
    brny67, JKBob 25 and chris4x4 like this.
  5. Dec 27, 2017 at 2:34 PM
    What are you comparing it to?
    A coil sprung Wrangler isn't bad if you compare it to an old leaf sprung Jeep CJ.
    The short wheelbase may make it seem rougher as the front end may not have had time to settle down before the back tires hit the same bump.
    DustStorm4x4 and JKBob 25 like this.
  6. Dec 27, 2017 at 5:46 PM
    mudbug85603
    mudbug85603 Active Member
    Jim
    Upstate SC
    Well they ain't Lincoln's...Like stated above the short wheelbase, spring rate, shocks, and tire pressure has some to do with it. Maybe if you share what your suspension is, along with brand of shocks. Size, load range, ply of the tires and what psi your running them at. We could make some suggestions to make it a little better.
  7. Dec 27, 2017 at 6:21 PM
    Welcome to the forum Johnny Jeeper. ^^^All of the above^^^
  8. Dec 28, 2017 at 4:48 AM
  9. Dec 28, 2017 at 9:30 AM
    mudbug85603
    Jim
    Upstate SC
    Had a '49 CJ2A..... yup that was a "rough ride" and took all day to get anywhere with the top speed of 45 mph....Had a blast doing it though
  10. Dec 28, 2017 at 9:39 AM
    Because of the short wheel base (WB) wranglers tend to be choppy, but not rough. CJs are a different animal. They are rough, but can be smoothed out with a few mods. If you are talking about the 2000 wrangler tell us if it is lifted or stock, what size tires do you have on it. Post some pictures of it on here so we can see what you are working with. The TJ should be a pretty smooth ride as far as jeeps go.
    DustStorm4x4, JKBob 25 and aggrex like this.
  11. Jan 22, 2018 at 11:07 AM
    brny67
    brny67 Member
    Bill
    17 JKU Sport
    Work in progress
    I thought the ride in my 17 Sport would be rough but I am really surprised and pleased with the ride, mine is lifted with 33 12.50
    JKBob 25, DustStorm4x4 and chris4x4 like this.
