98 Cherokee wont shift into overdrive
Discussion in 'Cherokee' started by Justine98cherokeeAwd, Nov 5, 2019.
  1. Nov 6, 2019 at 5:30 AM
    #21
    its midnight and you are still fretting...
    the jeep drives and there are issues -
    I am trying to help BUT three topics threads to read make this confusing... and information is in one and not another -
    stop using the threads below
    'Anyone know of a good parts website cheap?"
    " hay guys. love my 98 cherokee"
  2. Nov 6, 2019 at 5:38 AM
    #22
    help me help you- 1st have coffee, then we identify and plan.
    OK history -
    1) you changed the headlight switch? Why
    2) you removed cleaned and replaced the NSS - correct? jeep starts now ok?
    3) Anything else - wiring, fuses, electrical ?
    Issues you have
    A) no OD ?
    B) no CEL light when starting jeep? Scanners won't communicate?
    C) brake lights inop?
  3. Nov 6, 2019 at 6:49 AM
    #23
    Justine98cherokeeAwd [OP] Well-Known Member
    Justine
    Lehighton, PA
    98 jeep Cherokee Awd LIMITED
    What ? Is it confusing? I posted on other threads is that against rules?
    You have me confused now lol
    1. Engine light on
    2. No OD
    3. No reverse lights
    4. Cant communicate with code reader
    Im thinking i.may need new computer
    So...ive also been to other forums, but knowbody is replying so...
    Thank you tho
    I changed the headlight switch cus the rod came out. There actually was a spark when that happened but no fuses blew...still had OD. It wasnt untill i put a new headlight switch in and blew the headlight fuse..once i replaced that fuse is when my engine light was on etc..
  4. Nov 6, 2019 at 6:53 AM
    #24
    Justine
    Lehighton, PA
    Sorry, thank you for your help..I got my coffee now
  5. Nov 6, 2019 at 7:02 AM
    #25
    ok I am busy AND having trouble accessing the 1998 jeep information - OEM manual- I can handle ( adapt and overcome)
    The issue we will address first is the CEL.
    The CEL being ON we know there are codes...
    You did view tutorial on accessing with the key on off trick?
    Be sure its just the ON/run position not start you switch back and forth to. And finish in the on position - try again -your lucky.
    TMI
    My experience when scanners cannot communicate the issue is - no power (12v) on cavity 16 of the DLC.
    How is your comfort level with a test light ?
    NOTE you worked on headlight switch AND this supplies 12v to cavity 16 of ALDL on one of the wires.
    The circuit runs to the PDC (underhood fuse box) and a fuse.
    Getting that exact fuse # and location is what I am searching - I mentioned problem with 1998 manual.
    SO
    relax and try key on off trick again.
    Advise me if yu can use a test light or a multi meter?
  6. Nov 6, 2019 at 7:08 AM
    #26
    Justine
    Lehighton, PA
    I dont have access to test light, my dad does but i cant get it till tomarrow. And no meter
    Ill go out now and try the key thing again...
  7. Nov 6, 2019 at 7:09 AM
    #27
    Justine
    Lehighton, PA
    Oh you want me to check cavity 16?
    Thats unside the door pannel? I did check all fuses yesterday...
  8. Nov 6, 2019 at 7:15 AM
    #28
    Justine
    Lehighton, PA
  9. Nov 6, 2019 at 7:24 AM
    #29
    Justine
    Lehighton, PA
    Yea, doing key test now. Nothing happens, engine light remains on and does not blink. Wish i can record a video for u
  10. Nov 6, 2019 at 7:31 AM
    #30
    Justine
    Lehighton, PA
    I also did the test when u turn key on while holding odometer..it goes through some process..it did that but did not display any codes in the odometer
  11. Nov 6, 2019 at 7:36 AM
    #31
    Justine
    Lehighton, PA
  12. Nov 6, 2019 at 7:43 AM
    #32
    Justine
    Lehighton, PA
    Sorry for constantly replying..im in jeep researching. Ok my 98 , key trick doesnt work, i gotta to the odometer thing..and its not showing ANY errors.
    TinyInkognegroT likes this.
  13. Nov 6, 2019 at 8:06 AM
    #33
    Justine
    Lehighton, PA
    One last thing b4 i go back in my house...your saying CEL? Is that the "engine" light?
  14. Nov 6, 2019 at 8:33 AM
    #34
    OK I am busy at work and not 100% time wise - so S L O W going.
    With key trick look at odometer not the CEL* - thats your mileage not the light it should change to information ie 51 or P0302 characters.
    THE DLC, RE cavity #16 - Diagnostic Link Connector, where the technician would plug in to access your computer.
    I will add a diagram ASAP - have coffee/tea talk to dad about the tester.
    * CEL Check Engine Light
  15. Nov 6, 2019 at 8:54 AM
    #35
    under the dash is the DLC it looks like the diagram -
    look where cavity 16 is - in a corner of the connector. I believe there is no power here and what we need to check -
    The 4 corners of connector have terminals 1,8, 9, 16 - only the one we are interested is connected - so if confused just check all 4.
    Yes I know we still have brake lights and trans shifting to do BUT plan the work and work the plan
    Lunch time soon I will have a few free minutes. let me know..
  16. Nov 6, 2019 at 9:07 AM
    #36
    Justine
    Lehighton, PA
  17. Nov 6, 2019 at 9:09 AM
    #37
    Justine
    Lehighton, PA
    Ohh take your time, im delirious and operating on sleep deprivation lol.
    The place were tech will plug in pc does not work..they cant communicate...so the odometer thing isnt bringing up any errors
    Ive tried just about everything, from unplugging battery to stepping on the gas peddle 3x fast lol
  18. Nov 6, 2019 at 9:10 AM
    #38
    Justine
    Lehighton, PA
    Oh ok ill go back out in few minutes and look at that. Thx so very much...
    Be back soon have nice lunch
  19. Nov 6, 2019 at 9:55 AM
    #39
    Justine
    Lehighton, PA
  20. Nov 6, 2019 at 9:59 AM
    #40
    "What we've got here is a failure to communicate" We are trying to repair the
    We are trying to repair the connector, and the checking for voltage at #16. My experience this circuit is first place to check. ESPECIALLY as it runs to headlamp switch.
    Then we will scan and retrieve any codes -
    There is a reason to my logic.
