97 Cherokee trouble making it uphill going 55
Discussion in 'Cherokee' started by Billy1234, Aug 31, 2019.
  1. Sep 29, 2019 at 1:53 PM
    #21
    FYI: @TinyInkognegroT had a thread discussing CAT replacement: Universal fit vs Exact fit
    TinyInkognegroT likes this.
  2. Sep 29, 2019 at 3:16 PM
    #22
    TinyInkognegroT
    TinyInkognegroT Well-Known Member
    aggrex[QUOTED] likes this.
  3. Sep 29, 2019 at 4:40 PM
    #23
    Post video to YouTube and post the link here.
  4. Sep 30, 2019 at 3:02 AM
    #24
    Billy1234
    William
    1997 XJ 2 door
    None yet
  5. Sep 30, 2019 at 3:02 AM
    #25
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Think it worked
  6. Sep 30, 2019 at 3:57 AM
    #26
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Ok so now got to work the noise happened the hole was here driving and all
  7. Sep 30, 2019 at 5:55 AM
    #27
    :confused: confused - what? where? are we working on now?
    I want to hear its all fixed and you are headed off to fish... or scout for your fall hunt.
  8. Sep 30, 2019 at 8:07 AM
    #28
    Billy1234
    William
    1997 XJ 2 door
    None yet
    No working on a big addition in fayettevill (think I spelled that right) the noise is what's holding me back from going in to the ADK for a weekend on the trails to go fishin... the noise is starting to worry me
  9. Sep 30, 2019 at 8:28 AM
    #29
    Billy it's hard to tell from the video, but a bang in 1st when you let the clutch out sounds like the exhaust is hitting the cross member when the engine torques....or something.
    At the end of the video I could hear a tick tick tick sound that sounded like a leaky exhaust.
    Again it's hard to tell from the video and I know it's hard to get a video of things like that.
    Billy1234[OP] likes this.
  10. Sep 30, 2019 at 10:35 AM
    #30
    TinyInkognegroT
    I bought a 95 GMC Jimmy and it had a lack of power. It wouldn't get over 55 and I most definitely couldn't get up hills and I had no reverse. I drove it like that for maybe 2 or 3 weeks before I checked the engine. What I found to be my problem was my wires were crossed and the person I bought it from a couple of weeks earlier, I guess didn't notice it and assumed it was a transmission problem. Once I rewired everything back the way it should be, it ran like a champ... Still had no reverse though LOL. Your problem could definitely be an ignition problem (wires, spark plugs, distributor, distributor cap, etc.)... But I have also read later in this thread that it could be a possibility of a cat problem? Is there anyway you can shoot another video from under the vehicle and inspecting the exhaust and cat as the engine is running? You should buy an engine compression gauge, a fuel pressure gauge, and a vacuum leak down tester gauge. Harbor Freight has all three for under $30 each... And you can use those nice 20% off coupons ;)
    Billy1234[QUOTED][OP] and aggrex like this.
  11. Oct 3, 2019 at 10:37 AM
    #31
    Billy1234
    William
    1997 XJ 2 door
    None yet
  12. Oct 3, 2019 at 10:46 AM
    #32
    What - did I miss something?
    PS: get some new jeans. Thats what a fluffer at a Chippendale review wears.
  13. Oct 3, 2019 at 10:48 AM
    #33
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Lol there work jeans and do we even wanna know how you know that? The jeep wont go over 2 grand?
  14. Oct 3, 2019 at 11:11 AM
    #34
    I don't know what you do dressed like that - I guessed.
    Not going over 2k -
    start by checking for codes.
    All we did was drop the exhaust and clear the cat? My memory is BAD and long posts get away from me.
    Did you move distributor?
    Next would be to check fuel pressure with a gauge.
    Can you rev past 2k in park or neutral?
  15. Oct 3, 2019 at 11:29 AM
    #35
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Gutted the cat. Replaced wires plugs and cap. No codes that's the first thing I always check even with out the check engine light on. Did either the fuel rail or injectors to dont remember witch I did. And it's raining pretty bad so cant really check that right now. Jeep goes to 2500 in neutral then stops i got a video of that
  16. Oct 3, 2019 at 11:30 AM
    #36
    Billy1234
    William
    1997 XJ 2 door
    None yet
  17. Oct 3, 2019 at 12:06 PM
    #37
    this is a 1997?
    With no codes to go on then look at fuel pressure, and double check the connector and wiring to the CMP in the dist.
  18. Oct 4, 2019 at 8:45 AM
    #38
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Prerunner1982[QUOTED] likes this.
  19. Oct 4, 2019 at 9:14 AM
    #39
    Possibly, the exhaust manifolds are known to crack as well. It's typically when they crack, not if they crack. A loose collector (where manifold meets exhaust pipe) can also cause the sound.
  20. Oct 4, 2019 at 9:25 PM
    #40
    That looks like the muffler inlet has a crack. Usually creates just more exhaust noise.
    Billy1234[QUOTED][OP] likes this.
