90 yj 4.2 no spark
Discussion in 'Wrangler YJ (1986-1995)' started by Lineman1, Jun 10, 2017.
  1. Jun 10, 2017 at 8:44 PM
    Lineman1
    Lineman1 [OP] 1990 yj
    Sandy oregon
    1990 yj
    rear locker,garage fabricated rollbar, tube fenders,skid plates and rear bumper
    I have a nuttered yj that ran great for 10 years.It died while driving.Has voltage to coil 5.8v in run 10.6v in start. Pulled cap,rotor turns, replaced module (waste of $$)still nothing. I swapped the coil into another rig it fired right up.
    No spark at plugs,no spark to coil wire at cap.It sparks briefly when the key is let off start mode.
    Any help appreciated.
    I plan to do the HEI conversion but would like to resolve this issue first so I can address any issues with the swap on their own.
  2. Jun 11, 2017 at 5:18 AM
    If I had to guess I would say it is the electronics in the distributor. Get rid of the ignition module and coil, and do the HEI conversion with the integrated coil and all of that 5.8/10.6volts won't matter anymore. All you'll need is 12v
  3. Jun 11, 2017 at 8:31 AM
    Lineman1
    Sandy oregon
    1990 yj
    Yes I may have to just convert,pulled my dizzy this morning found the wire harness was very worn insulation was cracked and wire exposed where it passes through the housing. I have read the posts by Izzak JTHM71 and searched others now time to research the suppliers.
    I do look forward to cleaning up the wiring harness and simplifying things.
  4. Sep 9, 2017 at 8:49 AM
    Lineman1
    Sandy oregon
    1990 yj
    Problem never resolved ,Received my HEI conversion kit from 4wd parts 120.00 today and now installing.Hope this is a fix will let you know shortly.
  5. Sep 9, 2017 at 9:53 AM
    At the minimum it removes a variable. Sub'd for the positive outcome
