87 4.2 Resistance Wire to Coil
Discussion in 'Wrangler YJ (1986-1995)' started by YJ_Holse, Sep 23, 2023.
  1. Sep 23, 2023 at 6:25 PM
    YJ_Holse
    YJ_Holse [OP] New Member
    Russ
    1987 Jeep Wrangler, 258 5spd
    MC2150 Carb
    Hello, I'm rewiring and replacing some of my ignition components from the solenoid to coil and I'm trying to track down a resistance wire. Is this the grn w/wht trace that connects to solenoid with the black connector?, that then splices into bundle that goes to switched & yellow to coil .
    Thank you
    rh
