65 CJ5 Tuxedo park mark IV
Discussion in 'CJ' started by Strega51, Jan 30, 2024.
  1. Jan 30, 2024 at 3:44 AM
    Strega51
    Strega51 [OP] Member
    What's involved in converting 3 on the tree shifter to a floor shifter? I bought a 65 CJ Tuxedo that has the column shifter. I might leave it but curious what's needed to change it to floor shift. Thanks
  2. Feb 19, 2024 at 12:08 PM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    If you have not already figured this out, you need the shift tower from a regular T90 transmission (T90A, T90C, and T90J all use the same tower), a regular CJ 5/6 floor transmission cover, gasket, and plugs for the side shift T90 case shift arm holes. There could be many solutions to the latter. I would find a good used original shift tower as opposed to a recent reproduction, a lot of which are garbage. You can likely do this without pulling the transmission but it has been awhile since I had the floor plate off a CJ5.
    aggrex and Strega51[OP] like this.
  3. Feb 19, 2024 at 1:00 PM
    Strega51
    Ok, Sounds good. Thanks for the response and info.
