4.0 misfiring
Discussion in 'General Jeep Discussion' started by fishtale77, Sep 21, 2016.
  1. Jan 23, 2017 at 1:28 PM
    #21
    fishtale77
    fishtale77 [OP] Member
    fishtale
    01 grand cherokee 4.0
    Update. Turns out that i changed the cam position sensor and not the crankshaft position sensor. Fixed the problem after i put a new one of those babies in there. Also. After replacing all them parts,my gas mileage went from13 to almost 16mpg. ☺
  2. Jan 23, 2017 at 6:03 PM
    #22
    C2T
    C2T Well-Known Member
    Richard
    Helena, Montana
    Jeep
    Great!! :cheers:
  3. Jan 23, 2017 at 6:17 PM
    #23
    Thanks for the update!
  4. May 15, 2017 at 8:29 AM
    #24
    Did you ever fix this issue?
  5. May 15, 2017 at 1:01 PM
    #25
    Oh, I see that you did fix it. Great!
