2021 Jeep grand cherokee
Discussion in 'Grand Cherokee' started by PAwrestling#1, Aug 9, 2024.
  1. Aug 9, 2024 at 6:51 AM
    PAwrestling#1
    PAwrestling#1 [OP] New Member
    I have a jeep grand Cherokee that recently started spitting and sputtering losing all power. First time it acted up we had a message pop up to shift to park. So we pulled over and put in park and then the steering wheel locked up and could not move shifter. We then turn off ignition and restarted then acted normal for awhile. We still this spitting and sputtering without getting the shift to park popping up but we stull use the pull over shift to park and shutoff restart to get it to run ok for awhile. Took to our mechanic and had him run diagnosis on his snap on computer and got 3 codes: B1561-13, B224E-96, and B2860-15. Anyone know what could cause this and/or a fix or place to start? Dealer screwing me around.. 28,100 miles on vehicle.
  2. Aug 13, 2024 at 7:12 AM
    MackDogDiesel
    MackDogDiesel Member
    Paul
    2019 sting gray grand cherokee
    Steel front bumper, all terrain aggressive tires, side step rails, class 4 receiver with dual American flag mounts, roof rack, 10 LED light bars, rock lights, master control switch board, American flag decals, 2 inch lift, 2 inch spacers, slotted rotors.
    Symptom/Vehicle Issue: Uconnect Box Error Message, With Active or Stored Cellular Antenna
    Open or Short DTC:
    B1560-11
    B1560-13
    B1561-11
    B1561-13
    Discussion: “Uconnect Box requires service” message popup on the radio screen when vehicle starts. wiTECH shows one or more active or stored DTC(s):
    • B1560-11 - Cellular Antenna 1: Circuit Short to Ground
    • B1560-13 - Cellular Antenna 1: Circuit Open or Short to Battery
    • B1561-11 - Cellular Antenna 2: Circuit Short to Ground
    • B1561-13 - Cellular Antenna 2: Circuit Open or Short to Battery
    Every time the antenna open or short DTC(s) was set, the Uconnect box error popup will show on the screen. The message will stay on until next ignition off or customer closes the popup by pressing the cross button at top right corner of the screen.
    Please check the antenna harness connections on both TBM and antenna for proper installation,
    damaged connector locks, bent terminals or terminal push out. Check harness continuity and for cable pinch or damage.
    Do not replace the TBM module, if it could not be duplicated and DTC becomes stored. Most likely this was due to an intermittent harness connection concern.
    Code: B224E-96
    Definition:
    Power Liftgate Module Internal-Component Internal Failure
    Description:
    When the module senses an internal problem, this code will set.
    Cause:
    TROUBLE CODE PRESENT
    POWER LIFTGATE MODULE
    Failure Type:
    This sub type is used for failures where the control module has received an indication about the component that indicates a failure (e.g., an intelligent actuator or sensor) is indicating an internal fault.
    Code: B2860-15
    Definition: Door Ambient Light Control - Circuit Short To Battery Or Open.
    Description: An ambient lamp can be a: map pocket, door handle, halo ring, cup holder, etc. It is a LED with a built in circuit board.
    Cause: DOOR AMBIENT LAMP DRIVER CIRCUIT SHORTED TO BATTERY VOLTAGE
    DOOR AMBIENT LAMP DRIVER CIRCUIT OPEN
    DOOR MAP POCKET LAMP
    DOOR HANDLE LAMP
    DOOR MODULE
    Failure Type: Circuit Short To Battery or Open
    This sub type is used for failures, where the condition detected by the control module is the same for either indicated failure mode.
    Symptom/Vehicle Issue: Pinched Front Passenger Door Harness Causes Stop/Start
    To Become Inoperative, Bus Not Go To Sleep And Door Panel Lights To Remain On.
    DTC’s B2860-15 And P00FD
    Diagnosis: Inspect for M35 circuit (YE/VT)Passenger Door Ambient Lamp Feed and M36 circuit (YE/WH) Passenger Door Lighting Return circuits for pinching or damage.
    These circuits have been found to be pinched in Passenger front Door Panel (Circuits part of Passenger Door 2 harness) and causing a Short to Battery.
