12v jeep prob.
Discussion in 'General Jeep Discussion' started by jeepguy87, Sep 26, 2017.
  1. Sep 26, 2017 at 5:03 PM
    jeepguy87
    jeepguy87 [OP] New Member
    1993 white Wrangler yj
    I rebuilt my 2.5 in a 93 jeep yj. Put it in started to wire it up and now i have a 12v constant to block. Every electrical component in engine has been bought new and changed. Just can't find the wire or wires doing this. Any ideas.
  2. Sep 26, 2017 at 6:00 PM
    What do you mean Constant 12v to block?
  3. Sep 28, 2017 at 5:51 AM
    jeepguy87
    When you put a test light to negative battery terminal and touch anywere on jeep. Block or frame. The light comes on on the test light.
  4. Sep 28, 2017 at 12:26 PM
    Are you hooked up to your battery correctly. Red cable to the + sign side and Black cable to the - sign side. If so it sounds like you have a bare 12v+ wire touching both the block and the frame.
  5. Sep 29, 2017 at 10:29 AM
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    batt neg is not connected to frame , engine block
  6. Sep 29, 2017 at 10:32 AM
    2oldjeeps
    im convinced that most electrical trouble is created by work done wrong or messy wiring, NOT factory failures. components go bad, wires just sit there!
    Bob, JKBob 25 and chris4x4 like this.
  7. Oct 8, 2017 at 11:28 AM
    Rambler
    Rambler Member
    95 Wrangler 2.5 Bored 60 over AX5 D30 D35 NP231
    I inch Daystar Body Lift 30.95-15s Q95ooi
    Did you get this figured out ? Would like to know the outcome.
  8. Oct 17, 2017 at 4:50 PM
    Offroad798
    Offroad798 Well-Known Member
    Florida
    2015 Rubicon
    There is a lot of variables in this situation. I checked my shop manual and you should have a body grd and engine grd. Only you know what you fixed spliced or repaired so maybe look at what you may have done in repairs first. Also if you go to the power distribution center and start at one end and pull fuses to you get rid of your voltage reading then pursue that circuit to find the culprit. I listed some pics for you to look at. Let me know if you need any other help.
    Prerunner1982 and JKBob 25 like this.
